Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
15.1@90mph Is there something wrong
Old Oct 28, 2006 | 09:31 AM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
Transmission: 700r4 Built
Hey i have a 85 Iroc with one of those Made in mexico(helco) crate motors that came out of a truck , and the stock Qjet setup all stock except i an open element and a cutout my Q is should i be faster here is the times
15.1
90mph
2.180 60ft
.160 rt
also i just bought some 10" slicks and a holley street dominator intake manifold , how much do you think the manifold and slicks will lower my time
thanks, chris
Old Oct 29, 2006 | 12:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That's actually pretty good for that engine, if its the most common one. It has 76cc smog heads and only 8.1:1 or 8.5:1 compression ratio.
If those slicks are taller than the stock 26" tires, they might slow you down. Taller tires make your rear end act like its numerically lower.
The intake manifold is a good idea, those are usually good for 10-15 horsepower. But you might need an adapter to make it work with the Qjet.
Old Oct 29, 2006 | 01:47 AM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
ya i heard about the motors but atleast its a 350 so i have something to work with ,
the slicks are 26x10-15
just wanted to know also sinse there like 8.5-1 with 76cc if i get 54cc heads what will it raise it to
Old Oct 29, 2006 | 10:50 AM
Kevin91Z's Avatar
I havent heard of any 54cc heads. I know of the 58cc Corvette heads, Camaro 350 heads are 64cc's, and most aftermarket heads are 64 to 72 cc's.
With 58cc's, your compression goes up to 10.5:1 with a 0.050" head gasket. With 64cc's its 9.75:1 and with 68cc's its 9.35:1.
Old Nov 4, 2006 | 01:19 PM
Marc 85Z28's Avatar
You're not still running the stock LG4 exhaust manifolds are you?
Old Nov 4, 2006 | 02:35 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
If I were you, I dont think I would get off of that Yamaha long enough to worry how slow my f-body is.
When my 89 350 tpi L98 Auto w/2.77 Camaro, was bone stock w/K&N filters, it ran 15.2 @ 92 according to a g-tech meter. So your numbers arent to bad.
Anything you can do to make it breath better will help. First make sure its tuned up properly then do mods. In CA, you will have a harder time, making power, with emission regulations.
Headers will uncork any engine and let it breath better.
Good Luck.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
