Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Mid 14s possible?
Old Dec 21, 2006 | 12:14 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Mid 14s possible?
Would my combo get me to mid 14s.
350 bored .40 over
New Cam(Stock Size)
305 heads(dont know casting)
Edelbrock Performer 600 carb
Edelbrock Performer RPM Intake
Hooker Shorty Headers
2in True Duals
Freshly Rebuilt 700R4
TransGo Shift Kit
2500 Stall Converter
3.08 Limited Slip
Old Dec 21, 2006 | 03:21 PM
brutalform's Avatar
You must change your exhaust pipes, and mufflers... J/K.
With a stock cam and the 305 heads, I would think, mid to low 15s.
Put some sticky tires on and see what it will do.
Old Dec 21, 2006 | 05:52 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
why run a stock cam? And by stock cam which exact stock cam did you run? The stock 85 305 cam?
Some more gear wouldnt hurt.
Id be surprised if you werent in the 14's atleast... certainly if stock 350 tpis can do it.
Old Dec 21, 2006 | 07:54 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
get the cam specs and find out what cylinder heads you have and we'll go from there.
Old Dec 28, 2006 | 04:41 PM
MidnightBlue07's Avatar
Car: Z28 / GT
Engine: TPI 5.0 / 3V 4.6
Transmission: A4 / M5
Axle/Gears: 3:23 / 4:30
I'm not trying to be off topic but I'm also curious if this setup could also put me in the 14s , thanks
86 Z28 - 305 TPI
Edelbrock Hi-flo Intake
Edelbrock Hi-flo runners
TPIS airfoil
2055 Hooker headers/ y-pipe
Comp Cam Magnum 270H 224/224*...470/470 lift
Comp Cam 1.5 rockers
3in Custom catback exhaust
3:23 ratio
Old Dec 29, 2006 | 06:34 PM
mw66nova's Avatar
Engine: 7.0L
it better, i don't have much more camshaft than you, but i'm carbed and went 12.31 with a 4000 stall converter and 3.73's with a 28" tall tire. next year i'm going to a 3.45 9 bolt, but also going to a 26" tall tire and should be right around the same. i would think that your combo would be in the high 13's with a stock stall and 3.23's.
Old Jan 1, 2007 | 03:58 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
i went 14.4 with a 327, similar heads, a non RPM performer, 224/230 .477/.480 cam, shorties 2.5" exhaust, stock th350 trans and converter, 3.73 rear. went 14.8 with 3.08's but i suspect i could have gone 14.6 if i tried harder.
Old Jan 1, 2007 | 10:36 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
well a stock 305 tpi with the L98 cam ran 14.7. well thats what it ran when it was new from the factory.
i say if you hook good then you should see some mid to low14s.
Old Jan 3, 2007 | 05:45 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
What kinda of compression? Smogger 350 with those 58cc heads will net about 9.7:1, fairly decent, that cam sucks, the heads flow crappy, true duals are a pain on these cars, feasible, but a pain and you need alot more gear and better converter.
Old Jan 7, 2007 | 10:36 AM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
A lot of that will depend on altitude and weather, but yeah it's feasasble.
I went 14.34@ 97 with a 190,000 mile TPI 350 with hogged out runners, bolt ons, a five speed and 3.08's in 60* temps.
Old Jan 11, 2007 | 03:42 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
85T/A 350...
You really haven't done too mcuh to it
throw in some 3.73 gears..and a Cam and you will be running dood..
Something with .488 lift to get to 6000 rpm...for your intake
Your car will run pretty good then...
Cams are only 210 dollars from comp cams...its a GREAT mod..
P.S. ditch the heads too
cowansauto
Apr 3, 2025 12:51 PM
PestilenceIV
Sep 11, 2016 12:53 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
mdtoren
Aug 23, 2015 12:52 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
