Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
front runner ?
Old Jan 11, 2007 | 07:42 PM
chrisbarnes's Avatar
front runner ?
hello i am a newbie here.. i am building a stock elim 1983 fiebird... i am looking for advice as to what size front runners will fit...anyone have a suggestion...
thanks
chrisb
Old Jan 11, 2007 | 08:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Typically, most people start with 165R15 VW tires and they work fine however they're very short. A taller tire will give more rollout and less chance of cutting a red light. I use MT 28" tall front runners mounted on 3-1/2" rims.
Old Jan 11, 2007 | 09:16 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
thanks
chrisb
I run the Mickey Thompson 25x4.5x15 front runners on 15x4 weld magnum drags. I will get 26" next time to fill up the fenders a little better. They seem to react well.
Old Jan 11, 2007 | 09:49 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
will the 28" tall ones rub at all? I have the 165r15 tires and want to raise the front end a bit and I believe they're 25" tall or so, and would like to get some more ground clearance for my trailer.
Old Jan 11, 2007 | 11:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If I had steering stops they probably wouldn't rub but if I make an extremely sharp turn, they will rub. I try not to make very sharp turns.
Old Jan 11, 2007 | 11:39 PM
sixpackmtrspts's Avatar
if your gonna run stock elim run the biggest tire you can. i have seen many f bodys at pomona running 28 front runners.
customblackbird
Aug 15, 2021 10:16 PM
tazs2000
Jul 15, 2017 08:44 AM
deracer
Apr 11, 2016 12:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
