Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Hmm What Will She Run?
Old Jan 17, 2007 | 12:35 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
This Weekend i should be picking up my new engine for the formula (should hopefully have it in by spring time) so im just curious as to what you guys think she'll run in the 1/4?
Engine Specs
1995 LT1
Bored .030 Over
Mild Port Job On Heads
LT4 Hot Cam
1.6 Comp Cams Pro Magnum Rockers
Intake Runners had Weld Added to them and then Ported
Accel 30# Injectors
BBK 52mm TB
it'll be going in my 1991 formula... which weighs in around 3250lbs... 3.42 Rear end... and i'll be bolting my T5 upto it until i can afford a T56 (i wont be powershifting the T5 so well see how long she lasts!)
Old Jan 17, 2007 | 01:05 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
high 12s to mid 12s
Old Jan 17, 2007 | 05:30 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
Thanks!
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
