Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
video
Old Mar 24, 2007 | 07:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
video
Not sure if this third gen is a TGO member but the car looks interesting
http://www.youtube.com/watch?v=Wxc7pyLSKgI
Old Mar 24, 2007 | 07:23 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Re: video
Here's another one I found, it's pretty sweet.
http://www.youtube.com/watch?v=1DkkxHP9fS4
Old Mar 24, 2007 | 08:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: video
It starts better than mine does when it's cold. His shift light came on at only 4000 rpm. Not exactly a high reving blower engine. Probably babies it around the streets and likes to see the light come on.
RE the first video: (no offense if the owners are reading this) I watched their first video trying to start the engine. All I could think was it looked like a couple of red necks but without beer in their hands. Fishing poles were hanging on the garage wall etc. They never even had the timing close when firing up an engine for the first time. Most of the first video is them cranking the engine over trying to find the right timing to get the engine fired. If the camshaft was new, might as well pull it out and throw it away. Cam break in time came and went while they were trying to find the timing.
Old Mar 24, 2007 | 11:37 PM
DIGGLER's Avatar
Re: video
he may have his ignition box turning on the shift light at the launch rpm when he has his foot on the brake. (4,000 rpms)
thats how i have my digital 7 rigged at the moment.
Old Mar 25, 2007 | 11:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: video
Shouldn't it go off again at a higher rpm then? My tach has that feature. The shift light in the tach blinks just under the launch rpm, steady at the launch rpm but goes out if the rpms are too high.
I don't use the feature myself. I launch off a 2 step. The feature is only good for foot braking to allow you to launch at the same rpm every time. Providing you have enough time to do it.
Old Mar 25, 2007 | 01:05 PM
DIGGLER's Avatar
Re: video
there's a ton of setups with the dig. 7. when i hit the brake, it resets the ignition (so it knows its in 1st gear)
it also sets the rev limiter for staging the car, and it turns on the shift light once that rpm is achieved. you can setup what rpm it goes back off.
when i activate the line lock, it sets my burnout rev limiter.
when i turn on the nitrous system, it cuts the timing.
overall, its pretty cool, but can get confusing as hell. lol
Old Mar 26, 2007 | 09:14 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: video
that second video he is a member of TGO
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
L98GTA87
Oct 19, 2015 10:43 PM
jessejames82
Oct 16, 2015 10:11 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
