Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What should i run?
Old Apr 29, 2007 | 07:42 PM
408Firebird's Avatar
Car: 1991 Firebird
Engine: 408 sbc
Transmission: Th-350
Axle/Gears: 10 Bolt / 3.73
What should i run?
I was just wanted to know what i will run. I have just bought the car and i have all of those parts on my car. So what will i run?
408 csb
9.7 compression
ported "997" cast heads
1.5.1 roller rockers
cam
286/286 duration
.490/.490 lift
weiland dual plane intake manifold
hooker super comp 1 3/4 long tube headers
4 inch mufflex exhaust
holly 750 dbl pumper
373 gears
torque arm
sub frame connectors
Old Apr 29, 2007 | 08:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: What should i run?
13s maybe high 12s if you hook really well. Those heads are smogger garbage, and the cam is old technology as well.
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I'm sure that combo is good for 12s
Old Apr 29, 2007 | 09:18 PM
Car: 1991 Firebird
Engine: 408 sbc
what type of car are the 997 cast heads from then? Also while i am at it what do you think is the max rpm i should be shiftin at for this engine?
Old Apr 29, 2007 | 09:32 PM
Car: 1991 Firebird
Engine: 408 sbc
If I got some afr heads and a better cam were do you think i could be sittin in the low 11s?
Old Apr 30, 2007 | 04:37 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Running low 11s? I am not sure about that.A roller cam,AFRs and a properly setup car could run 11s easy in a 408 but I know a guy who ran vortec heads, comp xe 274 and 1 5/8 true duals in a monte ss and ran a 12.6 with a 2.1 60ft if I remember correctly and his car is a daily driver.Either way mild cam and good heads will make that car run at least low 12s if it is setup right.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
