Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
2nd Autocross, beat both 5.0 stangs in F-stock
Old May 3, 2007 | 09:39 PM
Midniteson2's Avatar
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
So i ran my second autocross, this last weekend. The Bird ran really well and i beat both 5.0 stangs that were running by over a second. My bird is a stock Base model 1991 Lo3 5speed. I plan to run in the F stock class, i know there are a lot of parts that i can put on my car that can help handling, and are still technically "stock" what parts should i look for From other 3rd gen models that will help handling, and or power?
Old May 3, 2007 | 09:59 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Re: 2nd Autocross, beat both 5.0 stangs in F-stock
awesome man...i run f stock too. beating mustangs are always fun. the only thing i can say for this class is to get a good set of tires if you don't already have them.
Old May 3, 2007 | 10:20 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
I would throw in a set of Koni Sports from Stranoparts.com and a set of Kumho 710s from tirerack.
That will put the blue oval boys minutes behind you... and that's a good feeling.
The best Oval is the blue Oval in your rear mirror!
Brian
Old May 3, 2007 | 11:46 PM
Car: 1991 Firebird
Cool i'll look into those, So are the front/rear swaybars and springs the same for all models? did Irocs and Formulas get bigger swaybars, lower springs? What were the parts that came on the 1Le cars. are any of those parts available on less rare 3rdgens?
Old May 4, 2007 | 01:00 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
In short yes. The sways varied in sizes and the springs in height and stiffness.
Old May 6, 2007 | 12:34 AM
Car: 1991 Firebird
and not in short? which years/models had bigger bars/ lower spring rates stuff like that.
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Lbibb
May 5, 2016 12:00 AM
sammy52401
Nov 11, 2015 07:20 PM
mfp189
Sep 27, 2015 09:25 AM
