does anyone know any good alignment specs for a drag car. i installed moroso coils in the front and needs an alignment.
Camber is zero but as the front end rises on launch, the camber goes out the window.
Caster, as much as you can get. I think mine is about 5 degrees on both sides.
Toe would be good at zero but around 1/16" toe in is preferred.
right on thanks for the quick reply
