Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Anyone Think It Will Do 12's?
Old Jun 11, 2007 | 01:18 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Combo is in my sig. Let me know what you think what you think the car should be able to do. I really want to solid 12 second car.
Old Jun 11, 2007 | 09:59 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Anyone Think It Will Do 12's?
those trickflow heads do low 12s with a carb application, not sure how big that cam is, and the stall seems kinda small, but go give it a try and post back.
Old Jun 11, 2007 | 12:35 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
So this summer I am thinking of getting a bigger cam. This is just the biggest cam that is street legal. But it isn't like they are going to rip my engine apart.
Old Jun 11, 2007 | 03:15 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
specs on cam? do you mean streetable or street legal???
Old Jun 11, 2007 | 03:36 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
lol most cams arent "Street lega" but who gives a damn, no one would ever know.
im running comp cams xe274 hydraulic roller cam, puts peak power right at 6000 on the nose, its a 224/230, with .510 lift with 1.5's
stall and cam are a must for your car, i would also think that as long as you have good springs on those TF heads you could really benefit from 1.6 rockers.
that head and intake combo are easily good for low 12's with a good 60 foot
Old Jun 11, 2007 | 04:00 PM
Car: 85 Trans Am
Engine: 383 ci
i really confused as to what you people are talking about. I mean come on "STREET LEGAL". this sounds like some F&F stuff. I know several 7&8 sec cars running in my neck of the woods and they are street legal. aka lights,seatbelts,exhaust,blinkers,mirrors,and licence plates. I have a solid roller in my car that has a duration @.50 of 252 and 618 of lift and my car is street legal. the bigger the cam the less streetable but i have never heard of an illegal street cam unless you cant fugure a way out of emissions as a result of.
Old Jun 11, 2007 | 04:41 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I live in Cali, So I have to smog it and everything. I mean it is a STREET LEGAL CAM. It is a 112. Which is why I am most likely going to get a bigger cam.
Old Jun 11, 2007 | 06:11 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
112 is just lobe separation angle, im running a 112 cam in my 355.
duration effects where it makes power in the powerband.
and lift effects how much air flow is coming in.
you want to make sure the cam's duration will make power where you want it, and you want your peak lift with whatever rocker youre using to match about what the heads peak flow is.
as far as living in cali, my only advice is to move to kentucky
Old Jun 11, 2007 | 06:14 PM
brutalform's Avatar
A ZZ-9 cam would get it done.
Old Jun 11, 2007 | 10:37 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What time would I run with a ZZ9, and how much does it cost?
Old Jun 12, 2007 | 01:32 PM
brutalform's Avatar
Years back when I had my 355, with TF heads, etc, I ran 13.00 flat, but my MPH was decent, at around 107. Had mid 12's potential, but I sold the engine while it was still new.
IIRC, the ZZ-9 goes for like $300.00. You will need new springs as well.
Old Jun 12, 2007 | 05:14 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
My springs are not stock, they are stronger ones for the heads and roller rockers. The springs that came with the heads weren't strong enough and broke, so My dad and I got stronger springs. The stall is matched to the performance of the car and selected by professionals. I drive the car daily.
