Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
motor block
Old Jun 21, 2007 | 09:58 PM
NICK84Z's Avatar
Car: 84z28
Engine: none
Transmission: TH400
Axle/Gears: moser9" 411gears 31spline
motor block
I had this in the engine swap forum and didnt get a lot of feed back so I thought I would see what you guys thought.
Hi guys,
Ive got some questions about this block GM Goodwrench#10066036 "hecho en mexico" I've had this 350 in my car for about 15,000 mile, I bought it used and it has worked well with just edelbrock performer stuff on it. Now I'm turning my car in a drag car and wanting to build a 383 with this block, I'm wondering how much this hp/tq this block can handle or if any of you have used this block for high performance 500+ power. I had a guy tell me that he has heard of goodwrench blocks cracking in the lifter valley? Anybody else heard bad news about these blocks?
Old Jun 21, 2007 | 11:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cracking in the lifter valley is usually due to freezing - e.g., not enough antifreeze.
But, the block should be carefully checked over before stroking it. If it is crack free, then a good solid rebuild with good rotating parts should allow it to do the job.
Old Jun 22, 2007 | 10:04 PM
NICK84Z's Avatar
Car: 84z28
Engine: none
Transmission: TH400
Re: motor block
thanks five7kid
Old Jun 22, 2007 | 11:13 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: motor block
what I found from the casting number
10066036...350...........2 or 4 bolt main....Target Master/Goodwrench crate motor
2-piece rear seal, "Hecho en Mexico"
if its not a 4 bolt block already I recommend having it drilled.
Old Jun 23, 2007 | 12:10 PM
NICK84Z's Avatar
Car: 84z28
Engine: none
Transmission: TH400
Re: motor block
Its a 4 bolt
Old Jun 23, 2007 | 02:10 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: motor block
just get it fluxed and if it checks out it should be plenty strong for 500hp. Though i prefer splayed 4 bolts over standard 4 bolt main block
Old Jun 23, 2007 | 02:57 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: motor block
on a street engine, 2 bolt or 4 bolt mains doesn't matter at all.
jhawkeye
May 25, 2022 06:33 PM
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
fbirdroller
Sep 2, 2015 10:27 PM
Mickeyruder
Sep 2, 2015 02:45 PM
