Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What kinda power should I be making?
Old Sep 9, 2007 | 12:01 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Heres the list of my mods..
-350 punched .030 over
-No smog equipment
-A/C removed
-Comp cam around 450 lift
-AFR 180cc heads
-Comp magnum 1.6rr's
-Wieand Xccelerator manifold
-Holley 4160 750cfm vac secondarys
-Headman shorties
-Flowmaster 3in catback
-Magnaflow cat
-T-5
-3.73's
Any info on what kind of power I should be making or e/t's?? Thanks
Old Sep 9, 2007 | 12:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Need more specifics about the cam. From what you have said, sounds like a head/intake/cam mis-match.
The carb and transmission are certainly a mismatch. Any particular reason you went VS? It's not going to play well with the manual tranny.
Old Sep 9, 2007 | 12:13 AM
Re: What kinda power should I be making?
after the AFR's i didnt have enough for the DP Ill go look for the cam card but i dont think i have it anymore.. its in the 450's with lift and duration is like 220?? Im not too sure.. probably not even close..
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
