Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Those With Wolfe Race Craft Anti Roll Bars
Old Sep 13, 2007 | 02:51 AM
JesasaurusRex's Avatar
Just got done puttin mine in the other day
When setting the initial ajustment are you guys doing it with yourself (or a person of your weight) in the driver compartment then ajusting the rear so that both wheels come up identically or with nobody in the seat?
Common sense says with somebody in the seat but...
Thanks in advance fellas
Old Sep 13, 2007 | 10:57 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Those With Wolfe Race Craft Anti Roll Bars
someone in the seat of course
Old Sep 13, 2007 | 11:11 AM
Those with them
but yea im 99 percent sure too, thing is when i did have the instructions i dont remember them saying anything about it.
Old Sep 13, 2007 | 05:04 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
the directions say without anyone in the car, I of course put my wife in the seat, jacked the front up until the tires just came off the ground, then measured the the bottom of the rockers to the ground and set the passenger side 1/16 lower than the drivers. it works fine as is but I would like to play with it to see if I can get the car to go a bit straighter off the pad, it still cuts right right off the brake.
Old Sep 13, 2007 | 08:14 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
My destructions stated to have driver in car when setting, so i had my uncle who is approx same wieght as me sit in the seat while i set link height.
does it make a difference...you bet....with just my racing, car leaves straight as an arrow...put a passenger in the car and she drives striaght right...scarey fast too.
Old Sep 13, 2007 | 10:57 PM
DIGGLER's Avatar
i set mine up with nobody in the car.
Old Sep 14, 2007 | 02:06 AM
k thx fellas, think ill set it with somebody in the car first
J-money
Jan 4, 2019 09:45 AM
Lanz06
Sep 14, 2015 07:16 PM
87camaro87
Sep 9, 2015 10:29 PM
Fronzizzle
Sep 8, 2015 12:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
