Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Finally used the juice Saturday
Old 09-25-2007, 08:52 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Well I got to the track around 10:30 and it was pretty packed because they were doing a $1,000 pay out at the same time with T-n-T. I only made 5 passes, 2 on motor and 3 on the juice. I only managed to run 12.14 @111 mph , 1.70 60 ft. I was only running 32* total timing. I normally run 36* that's why my mph was so low I'm hoping. I usally trap 115 or 116 mph. Well I didn't confirm my thoughts due to time. The motor passes looked like this:
1st pass: 60 ft--1.73
1/8 ET--7.89
1/8 MPH--87.35
1/4 ET--12.37
1/4 MPH--111.39
2nd pass: 60 ft--1.70
1/8 ET--7.69
1/8 MPH--88.40
1/4 ET--12.14
1/4 MPH--111.69
Now the nitrous passes: I launched on nitrous on the 3rd pass only to spin through the 60 ft mark and all the way out to 330 ft mark, so I got out of it. That was my first time using nitrous at the track, but come to find out I didn't check my tire pressure in my M/T street radials. I had 20 lbs in my tires, I started out with 18 lbs during all motor passes. I failed to check tire pressure. On my 4th pass a friend of mine that runs nitrous all the time told me to set tire my pressure at 15 lbs and launch on motor, then hit the nitrous after I shift into 2nd gear. So I did just what he said. On the 5th and final pass due to time, I set tire pressure at 14 lbs. The Nitrous passes looked like this:All passes where made with 150 shot.
3rd pass: 60 ft--1.90
1/8 ET--8.03
1/8 MPH--74.87
1/4 ET--12.98
1/4 MPH--110.02
4th pass: 60 ft--1.67
1/8 ET--7.34
1/8 MPH--96.55
1/4 ET--11.36
1/4 MPH--123.63
5th pass: 60 ft--1.66
1/8 ET--7.30
1/8 MPH--97.68
1/4 ET--11.29
1/4 MPH--124.34
I set my timing at 31*, bottle pressure was 950 lbs during all nitrous passes, and I never unbolted my sway bar too. I never got the chance to launch on bottle again after reseting tire pressure due to time. So I know I can get the car into the 10's if I can get it to hook. So tell me what you think?
Old 09-25-2007, 09:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Finally used the juice Saturday
Got a roll bar, fire jacket etc?
Old 09-25-2007, 10:07 PM
car_fixer's Avatar
what you need safety stuff to go that fast safety is important to consider but even the more basic stuff, are all the tires rated to go those speeds ( alot of street tires are not) battery secure proper seating and belts as motorcycle guys say dress for the wreck not the ride
Old 09-25-2007, 10:42 PM
zz17iroc's Avatar
I have a fire jacket, I am installing a cage over the winter. Yeah I got lucky and ran that last time before I got booted.
Old 09-25-2007, 10:46 PM
car_fixer's Avatar
technically i should been booted sunday cage isnt certified and i dont have a chute yet so i know what its like, ok jeggy sign me up for a prostock chute mount launcher and cable heres about 1k .. i could use that to go faster lol
Old 09-25-2007, 10:57 PM
zz17iroc's Avatar
Both you and Stephen 87 IROC are right about the safty issue . I need to take it really serious and legalize my car before I run it again, so that could be it for the year. Even though it's a daily driver. Thanks for your input fellas!!
Old 09-25-2007, 11:09 PM
car_fixer's Avatar
oh and one more thing, throw the stock brakes out the window, they suck, aerospace and wilwood make pretty good vented rotor street strip sets, i used aerospace drag brakes with the solid rotor and this thing stops awsome same track i couldnt make the second turn at 130 before at 146 with the new brakes i actually got off the brake to get to the turn and got some weight off in the deal too (uh cept now i uh need to get new headers)
Rocket-Doc
11-14-2015 02:08 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
JSDaddy189
09-26-2015 03:50 PM
Quick Reply: Finally used the juice Saturday
