Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
mighty 305's new best!
Old Feb 23, 2008 | 05:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
went out to Silver Dollar Raceway in Reynolds, GA today. car went a new personal best with this combo. decent air today too. 40ish % humidity, mid 70's for temps and 30.50" barometer. i'm trying to get ready for the upcoming bracket season starting next weekend. made 4 passes, all of which i had a 1.67 60' time. varied .008 to the 60' in all four passes. did pretty good on reaction time too. -.004, .007, .039, .038
here's the best time slip:
r/t: -.004
60': 1.671
330': 5.074
660': 7.947
mph: 85.21
1000': 10.445
1320': 12.568
mph: 106.08
so i dropped one tenth and gained over 2 mph just with the fuel system upgrade. i knew it was worth something! and the previous best of 12.66@103.98 was in pretty stellar air too. today was nothing to sneeze at for good air quality, but nothing like the mindshaft stuff we get in November.
Old Feb 23, 2008 | 05:57 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: mighty 305's new best!
^ Awesome run, congrats Matt....
-Rob
Old Feb 23, 2008 | 06:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
very nicely done, 3mph faster than what my old 305 did on motor, now just hit it with a 150 shot like I used to do to run 11.60s
Old Feb 23, 2008 | 06:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wow very nice times! that car is running good. whens the spray coming?? 11 second 305!
Old Feb 23, 2008 | 07:48 PM
mw66nova's Avatar
Engine: 7.0L
soon, but i gotta pull some gear out of it first. i'm thinking a 4.33 over the current 4.56's, but i'm not sure if it'll be enough. don't really wanna do a 4.10 cause i want to be able to get alot out of it on motor too. going through the traps right at 6500rpms with the .56's...all this is still on my drag radials too...i'm gonna hold on to 'em for a little while longer
Old Feb 23, 2008 | 07:53 PM
xpndbl3's Avatar
Car: 1984 Z28
6500 dang, i was shiting mine at 5700 way back in the day. talk about spinning it up for ya
Old Feb 23, 2008 | 07:55 PM
camaronut79's Avatar
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
nice, I can't wait to see what it does with alittle spray
Old Feb 23, 2008 | 07:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
wow that does seem alittle high. Where does that thing make peak power tho? i figured it be high with the cam you have
Old Feb 23, 2008 | 08:05 PM
mw66nova's Avatar
Engine: 7.0L
peak power is like 6200, i shift at 5900ish...it's likely a little over geared
Old Feb 24, 2008 | 08:04 AM
92 CaMaRo Rs's Avatar
Thats one quick 305 lol nice time.
Old Feb 24, 2008 | 09:59 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Goooooooooo! budget car!!!!!!!!!!!!!!!!
Old Feb 24, 2008 | 10:16 AM
Mike305RS's Avatar
How did you get your CR to 10.2? What kind of heads are you running, and is it TBI still or carb?
Old Feb 24, 2008 | 11:40 AM
mw66nova's Avatar
Engine: 7.0L
it was never tbi. the motor started out as an 85 lg4 way back in the day. if you look in my vB garage and sig it's got all my info, but i'll go ahead and say it again. the heads are modded 416's. have a small amount of bowl blending, the stock 1.84/1.5 valves with a backcut and we milled them to a 53cc combustion chamber. the car has a modded 650 double pumper on top of a holley street dominator intake p/n 300-36
Old Feb 24, 2008 | 12:10 PM
F-BIRD'88's Avatar
I wouldn't worry about changing the gear for a little nitrous.
use a moderate amount (100-150hp) right off the line and have the nitrous turn off on the top end say 6000rpm, using a "window switch" to control when the juice comes on and goes off. Then just hold 'er to the wood thru the traps.
This will limit the rpm and MPH thru the traps while on the juice. You get 95% of the et gain and all the fun, without excessive engine rpm.
When bracket racing, use the juice right out of the hole. Your opponent will see you stop accelerating at about the 1000' mark ( when the nitrous shuts off) and will naturally let off, to avoid breaking out,cause he thinks you are backing out of it to avoid a break out.
Try it. It's a lot lot easier to scrub off speed and et at the end than try to chase someone down.
Old Feb 24, 2008 | 12:16 PM
mw66nova's Avatar
Engine: 7.0L
eh, i'm not gonna spray when i'm bracket racing. the class i'm in is a 12.00 and slower class, that would put me too fast. but i like the window switch idea. i think i'll do that for my friday night test-n-tune play time!
Old Feb 24, 2008 | 12:18 PM
F-BIRD'88's Avatar
Should leave like a rocket on the spray...
I'm in the same boat. The fastest I can run the bird without a roll bar is 11.49 et here.
Old Feb 24, 2008 | 12:30 PM
mw66nova's Avatar
Engine: 7.0L
do you think my car would pick up over a second with a 150shot? (hypothetically)
Old Feb 24, 2008 | 12:51 PM
Car: 1983 z28
Transmission: th350
yes typically 125-150 shot shaves a second, some times more off your et. I have seen it happen soo many times.
Old Feb 24, 2008 | 01:08 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I went from 13.24 to 11.92 @ 117 on a 125 shot last season(355ci) with a 1.94 60ft and running VERY rich(9:8 a/f ) up top on the gas @5800ft altitude....so sorting out some issues should get me low 11's, i'd hope.
Old Feb 24, 2008 | 01:26 PM
mw66nova's Avatar
Engine: 7.0L
that gives me hope for even larger of a gain...think i gotta 10 second 305 on my hands with some spray? i'd have to put different gears in it though so i could spray all the way down the track...
Old Feb 24, 2008 | 01:40 PM
10 sec 305 is very possible if your tune is next to perfect and your using "good" gas(100-104), colder plugs etc.. so you can run a little more timing than with 91/92 octane. After you've nailed all that, your only limitation now will be the physical strength of your motor's internal components.
Old Feb 24, 2008 | 01:42 PM
mw66nova's Avatar
Engine: 7.0L
...about that...it's still got hyper pistons in it....it's got forged rods and an eagle cast crank, but those pistons...
Old Feb 24, 2008 | 01:55 PM
oh, well I wouldn't push it too much then if you'd prefer to keep it together...either way you're running 12.5's on ***** right now all you need is a 100-125 shot to be in mildly modded BBC territory with a 305 and that will be VERY respectable in any true hot-rodder's book. I know TONS of BBCs,BBFs and mopars that can't break 13.0's and they're supposed to be running well according to the owners....makes me laugh all the time.
Old Feb 24, 2008 | 01:58 PM
F-BIRD'88's Avatar
absolutley
Old Feb 24, 2008 | 01:59 PM
mw66nova's Avatar
Engine: 7.0L
i think this is what i'm gonna do. i'm gonna go with the Zex perimeter plate kit and put the 100pills in it. i'll likely go to a 4.10 gear since i probably won't be giving up on my 28" drag radials anytime soon. i'm building another motor right now, but it's gonna be while till it's ready to rock. once i get the new motor together, i'll lean on the 305 for all she's worth to see what it'll do. i just hope it holds together for that long, lol!
Old Feb 24, 2008 | 02:18 PM
F-BIRD'88's Avatar
with only 100hp you'd best try it with the 56's first.
JMO
Old Feb 24, 2008 | 02:47 PM
mw66nova's Avatar
Engine: 7.0L
aight...we'll see what goes down for the bracket season, see if i win any money so's i can buy some of this stuff, lol!
Old Feb 24, 2008 | 04:41 PM
xpndbl3's Avatar
Car: 1984 Z28
i went from 13.0 to 11.60 on a 150 shot out of my 305 spraying it right out of the tree dropping the whole way down the track.
Old Feb 24, 2008 | 05:36 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Congrats on the new best for the iron headed 305. As far as nitrous my old 327ci motor I had ran 12.90s on motor and on a 175 tune it went 11.30s at 118mph. This was around 14 years ago that little motor made a lot of money back in the days.
Old Feb 25, 2008 | 08:12 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Yeah Boy, That car is impressive. I saw it with my own eyes this weekend. Way to go man. Yes you should get the zex plate like I have, it's a real nice piece. I might hit the track this friday if the weather holds out. Then I'll hit the juice off the line, I didn't have time sat. Hope to see you there.
Old Feb 25, 2008 | 10:27 AM
mw66nova's Avatar
Engine: 7.0L
craig, you're the reason i wanna go with that plate. i really like the way it looked on your car and i've read some awesome reviews about it. i'm not gonna go friday cause i'm going saturday for the bracket race. you should come out and run the brackets with us man! see if ya can't win some money back after putting all of it in the car, lol! (that's my thought process anyhow)
Old Feb 25, 2008 | 01:05 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Congrats on the new best. Need to get my car back togeather so i can see what it will do now.
Old Feb 25, 2008 | 06:44 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
congrats!!!
Old Feb 26, 2008 | 02:20 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Nice #'s !!! Must be nice to be racing in February! Wouldn't mater anyway car is still in pieces from the suspension upgrades, and missing the drivetrain at the moment. BTW nice RT's as well
Old Feb 26, 2008 | 04:35 PM
mw66nova's Avatar
Engine: 7.0L
haha, the south does have it's benefits from time to time, lol! but it doesn't leave much off-season to afford to do major upgrades. hence why i've had the 305 for so long, lol!
i'm hoping my r/t's are that good this weekend and i'm able to see some $$$ at the race!
i'm gonna give the consistancy of the 60's some props. even though they're not super fast, they're really consistant. i put a set of rim-screws in and i really think that helped out alot. less than .005 variance lane to lane and only varried .008 over the whole day.
Old Feb 26, 2008 | 05:26 PM
F-BIRD'88's Avatar
Did you ever determine which component was causing the ignition problems with the Summit stuff?
Old Feb 26, 2008 | 09:15 PM
mw66nova's Avatar
Engine: 7.0L
the box. it was freaking out and resetting the limiters all the time. very annoying. not sure what i'm gonna do, but i'm leaning towards an msd digital 6, then expanding it later, but a digital 7 would do everything outta the box...
Old Feb 26, 2008 | 10:11 PM
car_fixer's Avatar
ahh, you dont need all that fancy stuff just throw a dual point dist. in there lol.
any way last year on a 150 shot, went 11.0's n/a and 9.99 on the bottle, on a progressive controller though, but it could leave on all of that, and was leaving on 225 at atlanta motor speedway but it also hooks in a car wash lol
ill run you on the bottle, ill run n/a , might even let you stage on the rears lol
Old Feb 26, 2008 | 10:35 PM
F-BIRD'88's Avatar
Whats your opinion on the summit distributor you had.?
Old Feb 26, 2008 | 11:31 PM
mw66nova's Avatar
Engine: 7.0L
that distributor seemed like a really nice piece. but i took all of that back. i might even suggest it. mallory makes all their ignition pieces. i would think it's just as good. i think my box was just a bad box. like i said in the other thread, they'd seen a few come back with similar weird issues.
rich, haha, bring it on big man, even though you run 10.8x's on motor, lol! i gotta win a few races before i can think about actually getting all this stuff. the zex kit is like $550! and i'm kinda agreeing with you on the "fancy" ignition parts, lol! i'm thinking "my hei works great...what's the problem with just keeping that and pulling timing out manually when i hit it with the kit?"
Old Feb 27, 2008 | 10:32 PM
car_fixer's Avatar
well honestly, a hotter spark would be good, but i would try what you got first...it should work with a 100 shot ok...and thats 10.6's lol
Old Mar 1, 2008 | 11:32 PM
  #42
mw66nova's Avatar
Engine: 7.0L
new best tonight, went back out at tried my hand at some bracket racing. would have done well had i not redlit in the second round, lol! anyhow, car went a 12.53 @ 105 on a 1.65 60'.
Old Mar 1, 2008 | 11:49 PM
  #43
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
very very nice! congrats man.
keep that up that thing MAY go 10's on a 150 shot
  #44
Stevo's Avatar
Car: Pair of 92 Z28s
Grats man...thats movin!
spray sounds fun and dangerous with those pistons. Best not to punch a hole through the piston this early in the season...lol. Im rooting for ya man id like to see that 11 second 305 you promised us awhile back.
70 degrees in february...must be nice. Though they are callin for 60s monday/tuesday up here.
Old Mar 2, 2008 | 12:17 AM
  #45
mw66nova's Avatar
Engine: 7.0L
yeah, me too! haha, i'm gonna try. i still got a few things to try yet, though i don't know if i can get another .5 off n/a as the motor sits...with more camshaft now...i think i could do fine, lol!
Old Mar 2, 2008 | 12:31 AM
  #46
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats not a roller cam is it? you should keep it a roller if its not
Old Mar 2, 2008 | 12:57 AM
  #47
87_TA's Avatar
Nice gain and times! I am not so much impressed that its a 305 than I am
you are using those 416 castings! Both are very impressive!
As for the spray, years ago when my camaro was 355 running 12.0, 100 shot gave me 10.8s.
I would deffinetly run taller tire or less gear if you spray, especially being n2os biggest gains are usually in the Torque department.
Old Mar 2, 2008 | 08:17 AM
  #48
zz17iroc's Avatar
Hey Matt, congrates again. Sounds like you got everything running well this year. Sorry I wasn't there yesterday to see it for myself, I kind of lost track of time. Go ahead and slap that NOS on their, a 100 shot should be good.
Old Mar 2, 2008 | 02:38 PM
  #49
mw66nova's Avatar
Engine: 7.0L
thanks guys! no, the camshaft is a 280h hydraulic flat tappet camshaft. i'm thinking of going back to a solid flat tappet camshaft over the winter. also, i'm going to a forged piston and get it ready for spray next season!
Old Mar 2, 2008 | 09:45 PM
  #50
car_fixer's Avatar
I thought about going down there to watch...but i was lazy lol and .5 is alot to find from thin air on a package thats working pretty good
