Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Fuel cell
Old Feb 27, 2008 | 12:41 PM
SMM's Avatar
SMM
Fuel cell
I have just installed a fuel cell in my 82 camaro but have found out that it can not be in the drivers compartment. It is currently located in the very rear of the car and I was looking for some advice. I was told I could make a sealed box to put it in or I could fab a firewall that sealed against the glass. Please post comments of pics if you have as this is the finale piece before we can make a pass.
Thanks,
SMM
Old Feb 27, 2008 | 02:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Fuel cell
My old system when I had a fuel cell in the rear.
Old Feb 27, 2008 | 06:55 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Fuel cell
im in the process of doing the same thing myself and i was planning on doing just what you have done stephen, looks good. only difference is i have the RCI 15 gallon street rod cell. hope it turns out well
Old Mar 3, 2008 | 05:02 PM
jeff lucas's Avatar
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
Re: Fuel cell
did you find out about what you could do about where u have it mounted, i am in the process of building my 92 camaro and have installed the rci 16 gallon in the rear on that flat deck in between the two rear bars on that picture u posted. i hope they dont make me seal of the rear half of the car.
Old Mar 3, 2008 | 05:29 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Re: Fuel cell
if you are going to take it to a track im pretty sure they are gonna want a firewall between you and the cell. i havent had mine to the track with the fuel cell in it yet but im going to put a firewall between us anyway. stephen can probably back me up on this. its probably a good idea to have one even if its just a street car with a cell.
Old Mar 3, 2008 | 05:34 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: Fuel cell
You are going to need to block it off. I had made a metal cover that slid right over the cell and they passed me at a couple different tracks. I drilled a hole in the cover for the vent and was ready to go. Plus its just safer.
Old Mar 3, 2008 | 06:10 PM
jeff lucas's Avatar
Car: 92 camaro rs
Re: Fuel cell
well i guess i will have to block off the back half, from where the back seats rest on the vertical to the roof ever seen anything like that. and what material would be best for a mod like that.
Old Mar 3, 2008 | 10:41 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
Re: Fuel cell
get a rule book! it has the specs you need for a firewall.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
89fast5oh
Sep 27, 2015 09:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
