Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What do you guys think(Guesses?)
Old Mar 17, 2008 | 02:24 AM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Finally got my motor back together and finished, race season is comming up soon. Just curious what you guys think my ET's will be.
*406sbc
*Stock crank and rods(upgraded bolts)
*Dished pistons 10.5:1 compression
*Custom grind retrofit Hyd. roller cam .585/.599 lift 238*/248* duration @.050 113LSA
*World sportsman II's, fully ported and polished, Angle milled to 62cc Chambers, 5 angle valve job, 2.02/1.6 Manley stainless steel valves, Comp cams 1.550 springs good for .700 lift, 10* locks and retainers, 7/16" ARP rocker studs and Comp cams guide plates.
*Vic Jr. #2975 manifold
*Holley HP series 750cfm carb
*Hooker 2210's,custom y-pipe and SLP loudmouth exhaust
*Th700r4 with 3200 stall converter
*Aluminum 4th gen driveshaft
*10bolt rear with 3.73's and a eaton unit (for now)
*Mickey Thompson ET streets DR's
I have flow numbers for the heads if you guys need them, Just curious to see what to expect out of this car. I know I probably shoulda gone better with the heads.
Thanks Guys!
Old Mar 17, 2008 | 02:47 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: What do you guys think(Guesses?)
12.0s until the trans or 10 bolt give up the ghost.
Old Mar 17, 2008 | 08:49 AM
Engine: 406sbc
Transmission: TH400
That same topend put down 525rwhp on my buddies 383 stroker, I know I wont put down that kind of number but with close to 500rwhp you think just 12's? Is it due to the rearend and tranny? Lack of stall? I have a 9" I'm building but it wont be ready anytime soon.
I also have a Jegster TQ arm
UMI sfc's
Lakewood LCA's and relocation brackets.
Old Mar 17, 2008 | 10:42 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
why so lazy on the camshaft? that wide lsa looks like it'll love some spray, but for an n/a motor, i'd have gone to a 108-110lsa. i think it'll want more converter and more gear down the road to perform to it's best ability but i think i see that you are trying to build a dual purpose street/strip weekend warrior with good street manners. those cylinder heads leave alot to be desired too but go ahead an post up those flow numbers to give us real perspective.
Old Mar 17, 2008 | 10:58 AM
xpndbl3's Avatar
Car: 1984 Z28
prove me wrong then by taking it to the track
These threads are soo pointless, guys like me and mw66nova got low 13s, even 12s out of stock headed 305s....and 99% of the board is in the mid to upper 14s with them. It's all in that magical tune and suspension setup.
Old Mar 17, 2008 | 11:16 AM
Engine: 406sbc
Transmission: TH400
I dont liek these threads really but the track isnt open for another month here and I was just curious. The cam is actually going to love the spray, I plan on a 150 shot. The heads flow pretty well...
LIFT VALUE
INTAKE FLOW CFM
EXHAUST FLOW CFM
0.100
68
53
0.200
144
106
0.300
206
144
0.400
242
173
0.500
258
201
0.600
273
213
I dont plan on doing anyhting else to the motor just fine tuning the suspension and driving the hell out of the car. I was hoping to hit a 10.xx on the spray. I didnt invest much in the tranny or 10 bolt, I have a 9" I'm building with a full spool and 4.30 gears along with a 4200 stalled TH400. Just need some more time and money to finish everything.
Old Mar 17, 2008 | 05:23 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
For such a small shot of nitrous you do not need a wide lobe sep. use a cam with a 106-110 will work better on motor. Good luck I think you have a combo for high 11s to low 12s
Old Mar 17, 2008 | 08:00 PM
Engine: 406sbc
Transmission: TH400
How much do you think the 9" and the 4.30's will help?
Old Mar 17, 2008 | 08:42 PM
xpndbl3's Avatar
Car: 1984 Z28
gearing will help, and not to mention you can floor it out of the hole, but 4.30s is kinda steep unless you want taller tires on the back. Do an rpm calculator.
Old Mar 17, 2008 | 09:00 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
UMI sfc's
at 501rwhp i ran 10.8@126 and thats with a 700r 4000stall and a 12 bolt. i had been 11.6@119 on a 10 bolt with a smaller kit.
Old Mar 18, 2008 | 04:34 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
2.02/1.60 is way to small for your combo, you should go a little bigger on the intake, 2.08's would be much better
Old Mar 18, 2008 | 09:50 PM
Engine: 406sbc
Transmission: TH400
I thought so, to be honest but I am stepping up to either AFR 210's or 227's next year along with a bigger nitrous shot.
Cleotiz
Jan 6, 2018 08:56 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
gwade12
Aug 8, 2015 08:17 AM
