fuel pump mount
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
fuel pump mount
ive got a holley hp 150 fuel pump and i need a place to mount it. im not putting a sump in and not running new fuel line to the take but somewhere at the filter is where i would like to tie in any thoughts? pics would be great.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: fuel pump mount
sump it. can't believe you're not even going to remove the intank pump either. that filter needs to be as close to the tank as possible, the filter area is too far forward.
Car: 86 camaro
Engine: 385
Transmission: glide
Re: fuel pump mount
the in tank pump has been out forever, im switching from a mechanical to electric. ive got the pump mounted i cut the floor out where the filter is and mounted the pump. now i just need to tie in after the filter and run my new line.
92camaroJoe
Aug 13, 2015 06:07 AM
