Torque arm suspension and drag racing
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Who says a torque arm suspension won't let a car hook?
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Torque arm suspension and drag racing
I don't think he can get a good et with all 4 wheels off the ground
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Isn't that one of the fastest drag radial nitrous cars? I remember seeing a thread about that thing somewhere...
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
That pic is on PA Racings site. He is one of the customers and it says that it went 7.87 @ 181. the car weights 3450 and has a 565 BBC. Here is the link
http://paracing.com/article_info.php?articles_id=5
Car: 87 IROC L98
It's Smookie's car. First radial tire car into the 7's. A big BBC with 2 stages of NOS.
You can see lots of goodies under the car. Ford 9" diff, not tubbed out. Torque arm suspension, front coil over's on factory style struts. Tubular k-member, rack and pinion steering. Header tubes go on the inside and outside of the frame rails. Looks like a Stef's oil pan.
Transmission: 4L80E/4L80E
Car: 87 IROC L98
Found some more pictures of the car.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i want a big block some day but i cant get over how tall those motors are
thats a big hood
i'll settle for a big inch smally or lsx with some boost to make up for the power/torque. That car is hot tho!
thats a big hoodi'll settle for a big inch smally or lsx with some boost to make up for the power/torque. That car is hot tho!
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
that car has a BMR torque arm and the car got stolen over a year ago, he has built another car since then. it dont look as good, but it will when its all worked out !!!!
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
that's an absolutely beautiful plumbing job!
i wonder how the strut mounts looked after "touch down"
anybody know if there are "after" pics?
it would be a great study on the true impact resistance of our cars when they're under duress.
i'm not saying the third gen's are for "dukes of hazard" jumps, but how often do you get that kind of impact information?
i almost don't want to see the "after" pics! that's one beautiful setup.
Eric B
Eric B
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
just curious what kind of tourqe arm is he using.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Car: 1987 iroc z
oh im retarted lol is the sphon torque arm about the same or is the bmr stronger
well I happen to have first hand experience with this subject, I stood it on the bumper, and when it came down, it did less then i figured it would, however i do think the front is slightly tweeked. I extended the upper strut mounts about 1/2 inch, I could slide a large screw driver under them lol, and flattened the headers some, bent the hell out of the collectors from the exhaust comming down, scrapped the front bumper some, and if i ever take the oil pan off it will not go back on im sure, all in all not bad
Car: 89 Iroc-z
Transmission: TH400
^^^^^^^ yeah thats not all that bad i guess
.... jeez man sounds liek the car took a beating!!
.... jeez man sounds liek the car took a beating!! Thread
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
