Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What class does your car fall into
Old Aug 3, 2008 | 10:48 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
I'm building a 406 w/ Brodix cylinder heads, Holley Stealth Ram intake, and 4340 crank & rods, hi-comp pistons, etc. I was looking at the NHRA rulelbook to see what class I would fit into & I didnt find one I fit into.
Is there a class for unlimited mods?
Old Aug 3, 2008 | 11:59 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What class does your car fall into
It's called ET brackets. It's based on your ET and nothing to do with modifications.
Each track seems to have it's own ET breaks but typically...
14.00 and slower is Sportsman
12.00-13.99 is Pro
11.99 and quicker is SuperPro
In Superpro, you're also allowed to use a delay box and throttle stop.
You won't fit into the Stock/Superstock classes with any of those modifications. If you can get it down to 10.90, you could run in Super Street.
Chances are you'll be in the Pro ET class.
Old Aug 3, 2008 | 01:11 PM
3rdBird's Avatar
Thanks, my bone stock TPI is running 12.4 @ 105. I'm hoping the new motor will us into the low 11's, mid to high 10's on the bottle.
Old Aug 3, 2008 | 01:43 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Axle/Gears: 3.55
actually per nhra super pro is 11.99 and faster with a delay box. must have delay box.
and pro class is from 13.99 to 9.99
i know because i run pro no box and i run 10.000 dial
and sprotsman is i beleive 11.99 and slower with dot tires. no slicks
Old Aug 3, 2008 | 02:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Like I said, it depends on your local track's rules. Some allow Pro cars to run to 10.0. Others allow Pro cars to run to 7.50 or 8.50 with no electronics. Very rarely will you see SuperPro to run slower than 11.99. Having an overlapping ET break allows the quicker cars to stay in the Pro class without having to race against cars with electronics in SuperPro.
Since when is a delay box mandatory to run in SuperPro? A delay box is considered electronics. If you're running a footbrake or transbrake car without a delay box and you're quick enough to run in SuperPro, they can't stop you because you don't have a delay box.
Old Aug 3, 2008 | 02:36 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Exactly, depending what track i'm at, payout, car count i pay close attention to the S/P car count and once in awhile stars align and i double enter pro and super pro. The delay box does not promise a good R/T. It does give a better shot at a good R/T since your getting a fresh hit at first light, but i can tell you from years of experience, the S/P guy's dont cut any better lights than the guys i run in pro...only difference, these guys have top notch equipment, years of experience so mistakes are very few and you have to be perfect each pass to get to the next round, but they're not that hard to beat if you know your stuff and know how they dial since most hold a little...they're trapping 170+mph, i'm trapping 125mph so their ability to drive the stripe is no better than mine, so it becomes a dial and dump game 90% of the time for both of us LOL!!
I wish our pro class was as tight as Stephens class break downs, would make my job extremely easy driving the stripe, but as it sits, my track is 0.00 to 12.99 so the door is wide open to whatever wants to run...so it does create problems with the huge mph differences we get, it also makes you a better driver since now your having to not only beat the tree, take the stripe, your also having to watch the other guys and see what they really run as opposed to what they're dialing, since sometimes you win by letting them have the finish line first just alot of BS in this game ya gotta pay attention too.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
