Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
hood weights
Old Nov 2, 2008 | 08:10 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
hood weights
I have finally decided to get a fiberglass hood over tubular a arms for drag racing weight savings but am unsure whether to get a lift off or bolt on.
Does any one know the weights of:
Stock steel hood
Fiberglass bolt on hood
Fiberglass lift off / pin on hood
Old Nov 2, 2008 | 08:25 PM
85SILVERBULLET1's Avatar
Car: 85 Trans Am
Engine: 383 ci
Transmission: Liberty Geared Tko 600
Axle/Gears: Moser 9" 4.11 gear wavetrac locker
Re: hood weights
Lift off hoods are a pain in the ***. Not to mention they are usually pretty thin and the glass may look a little wavy. I have a glasstech 4 inch cowl and it was not much lighter than the factory TA hood.
Old Nov 2, 2008 | 08:26 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: hood weights
I've got a factory z28 fiberglass hood, it's not much lighter, if any, than the factory steel hood.
Old Nov 2, 2008 | 09:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: hood weights
I use a factory fiberglass hood. It's lighter than a steel hood but it's still heavy compared to a thin lift off hood. I've gone through a few of them over the years trying different things. I keep an eye out while in the junkyard for more but haven't seen one in a couple of years now.
As mentioned above, lift off hoods are a pain. A third gen hood is approximately 5' x 5.5" in size. That's a huge hood to lift off by yourself.
One of the main reasons I don't use a lift off hood is that I don't have a pit crew and my fuel cell is mounted up front. I have to open my hood after every round to top up the fuel. With such a big and heavy hood, that task becomes impractical many times a day.
I do remove my hood if I have to pull the engine. After unbolting it from the hinges, it doesn't take that much to lift it up and put it on the roof while in the garage but it's still a chore.
I use hood pins at the front corners and have installed 2 Dzus fasteners at the rear and 2 at the front to keep the hood from lifting at 110+ MPH. The scoop catches a lot of air. A full lift off hood needs at least 4 Dzus fasteners down the side and 4 across the front to hold the hood on. With that many fasteners, lets hope you don't need to get the hood open in a hurry.
Old Nov 2, 2008 | 09:51 PM
Car: 1987 firebird
Transmission: 4l60e
Re: hood weights
OK, it sounds like the lift off hood are a pain and there is not that much weight savings with a bolt on. I also know that there is a very good chance that a fiberglass hood will not fit as good as the factory steel hood. So is a fiberglass hood wirth $500+????
I would want the ability to open the hood inbetween passes so the bolt on one sounds more attractive to me, but if it is not going to save me a lot of weight I am second thinking.
Old Nov 2, 2008 | 10:00 PM
DIGGLER's Avatar
Re: hood weights
i hate my lift off hood and have been considering going back to a stock hood. or at least fabricating some sort of hinges for this one.
Old Nov 3, 2008 | 12:00 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: hood weights
Any fiberglass hood including a factory one is a weight saving over a steel hood. The factory fiberglass hood however has those stupid fake inlet scoops in it. If they had made a flat fiberglass hood, it would have been so much better. When I put a cowl onto my hood, I needed to get the longest cowl available in order to cover the indents in the hood.
An aftermarket hood gives you many options as to what kind of hood design you want. Flat, cowl, IROC, etc all molded directly into the hood.
Old Nov 3, 2008 | 12:11 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: hood weights
Guess, I'm in the minority, but I love my lift off 4" cowl VFN hood...all 12 lbs of it!!!
Old Nov 3, 2008 | 12:35 PM
project89's Avatar
Re: hood weights
i have a bolt on 2.5 in cowl and i love it deff lighter then the stocker.
ive also done the 4inch lift off cowl hood before, i used 4 pins 2 front and 2 rear.
the liftoff was easy enough to take off myself but it was harwood so it had the ruff finished underside and i did manage to scratch the roof of the car up a bit setting the hood up there.
if u do go with a liftoff hood do urself a favor and hot glue 4 sponges around the edges of the hood so when u take it off and set it ontop of ur car dont scratch the roof all up
Old Nov 3, 2008 | 05:46 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: hood weights
i thought about going with a pin in hood but i just couldnt get the thought of a underhood fire our of my mind and me lookin like a idiot trying to hurry and undo all those fasteners, especially if you are a one man crew. just food for thought.
Old Nov 3, 2008 | 06:28 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: hood weights
I have a 4" glasstec lift off hood. I love it weighs 10 lbs i think. I am 6'2" and my arms are easily long enough take the hood off by myself. I love the look on peoples face when i take it off by my self.
Old Nov 3, 2008 | 07:00 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: hood weights
I also run a lift off fiberglass. It is a pain in the *** to take off. I hear it crack a little every time I take it off myself. Hopefully when I paint it, it doesnt crack the paint. Sure is light though.
I also worry about the amount of time it would take to get it off in case of a fire....
Old Nov 3, 2008 | 07:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: hood weights
if you dont need a cowl hood, VFN sells stock style glass hoods
checked they have it, they also have formula style hoods, they are both 18 lbs for a bolt on.
the 4.5" cowl is 22lbs.
http://www.vfnfiberglass.com/site.htm
Old Nov 3, 2008 | 07:49 PM
Car: 1987 firebird
Transmission: 4l60e
Re: hood weights
I am going to go with a stock style hood and thinking a Glasstek at the moment. But what is everyones thoughts on VFN or Glasstek?
Old Nov 3, 2008 | 08:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: hood weights
my vfn hood required a bit of finishing, has some pinholes in the gelcoat. But the fit is very good
Old Nov 3, 2008 | 08:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: hood weights
i love my glasstek 4" lift off, no more banging my head when working on the motor at the track, there's ALWAYS someone who could give you a hand to pull it off.
Old Nov 5, 2008 | 08:35 AM
87_TA's Avatar
Re: hood weights
I had the VFN 4" bolt-on for my TA that they advertised as some rediculious weight of like 15 lbs - it weighed more like 25, when I contacted the company they said it was a missprint - guess what, same missprint is still there! hmmm.
I also hated the fit, ended up using the factory hood.
Any weight you take off the front is good weight reguardless though... So deffinetly worth looking into. Lift offs are deffinetly a pain on these cars, more so on Camaro's.. I have one on my mine, its hard to do by yourself especially if you have a nice paintjob - I don't , if you have a Camaro 82-83 Z28's came with factory fiberglass hoods that are hard to come by, great fit heavy duty and lighter than factory. I happen to have one to
Old Nov 5, 2008 | 09:30 AM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
Re: hood weights
i have the glasstek 4in cowl bolt on hood on my formula, it fits great and there are no problems with it yet
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Damon
Sep 26, 2015 04:29 PM
