Leak
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Leak
I am having a problem with my headers leaking at the gasket ( gasket that bolts to head) and I was wondering what gaskets you guys are running? I have a set of Hooker long tubes part #2210. Thanks for the advice.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Leak
spray the felpro gaskets with copper spray then use stage 8 locking header bolts for leak free seals if the header flange isn't warped itself and causing the leak.
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
Re: Leak
My Hedman's leaked from day one.
Took them off when changing motor and checked them with a straight edge.
2 of the 4 tubes were cut at a slight angle on both headers where they meet the motor.I evened them out with a grinder ,but have yet to fire it up and check them .
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Leak
Also, make sure that you have the header gaskets for the heads and not the ones that came with the headers. If you have D-port heads, get the D-port header gaskets.
