need some help breaking the 8s
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: need some help breaking the 8s
changing from 69 jet to a 67 jet in the primary led to .2 slower times. But it runs better on the street. Is it possible to have to lean the primary jets and richen the secondaries? or should I just change it back?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Did you get the 60ft times?
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
leaning out the primarys helped driveability, but leaned out the overall mixture enough to kill some power..... Now richen up the secondaries a little and see what happens.... Now you will get full power and better fuel economy...
Car: '89 IROC-Z
Engine: 355
thats what i ended up doing, been rained out last 2 weeks
Car: '89 IROC-Z
Engine: 355
Getting ready for racing season, heres whats been done new for this year:
Fiberglass cowl hood
Weld rims pizza cutters and L60s
Drag shocks and struts
SFC's
Tubular Adjustable torque arm and RLCA's
Autometer tach and shift light
I dyno tuned this thing last year and got the carb and timing all set up right.. I'm going to put gears in it just not sure what to go with there is a 3.73 ten bolt on craigslist I might check out, or should I just buy gears 3.90s or 4.11s???
SFC's
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Good luck man. I hope you get some good et's.
You lost weight with the skinnies and hood, but added with the sfc's. The good new is most of the weight you lost was off the front. Plus less rolling resistance with the skinnies.
The LCARB's should help with the 60ft also.
I would get some runs in and compare the et/mph before changing the gear.
Car: '89 IROC-Z
Engine: 355
Well I kind of want to change the gears anyway just not sure what to go with. I might relocate the battery to the trunk too. Racing seasons almost here cant wait to get some runs in.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
It all depends on you tire height, 60ft, mph, current gear, cam rpm range, and what rpm you are at when you cross the line.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
sjorgens
Oct 1, 2015 07:54 PM
