Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What would I run?
Old May 17, 2009 | 09:12 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
What would I run?
Just curious what I could expect to run.
This is the engine I have: http://tuffdawgengines.com/chev_350_440hp.htm
Stock 3.42 open differential
G-Force T-5 transmission, with the straight cut gears & dog-ring engagement, I can shift without the clutch (2.94, 1.94, 1.34, 1.0, .59 gear ratios)
Stock V6 suspension, except for UMI subframe connectors. Running on stock street 215 tires. No real weight reduction done.
Only other thing to note is I'm running at a little over 5,000 feet elevation. Obviously, my 60' will be awful, but any estimates on my overall E.T. and mph? Any other info you need for a decent estimate?
Old May 18, 2009 | 05:51 PM
86 IROC's Avatar
Re: What would I run?
No posi and the skinny street tires are really against you. I don't think the car will hook until 3rd gear. And, you already knew that 5K feet elevation is going to impact times as well. No offense, but uncorrected for altitude... most likely 15's or slower and very traction limited.
Old May 18, 2009 | 05:57 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
seems like you should be in the 12's but thats just me. With around 400hp to the wheels and if you can drive i think it should.
kevin
Old May 18, 2009 | 10:34 PM
Should give me a REALLY impressive one-wheel peel...
Thanks for the responses guys.
Old May 24, 2009 | 11:18 PM
Sorry for bringing this thread back, but could someone give me a MPH estimate? I know the E.T.'s will have too much to do with traction to give a good estimate, but since you know the horsepower you should be able to give me a good guess at the speed right?
Old May 24, 2009 | 11:40 PM
Redlinerevver's Avatar
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
Your going to have to run slicks or some street radials. I ran My car for the first time on street brand new 295 kelly charger street tires and I ran a 16.30 at like 86 mph.. I burned the tires through all the gears no prob with posi.. Then my sec run I just took it easy of the line then pined it and still burned out and ran a 14.70.. To end my story I baught a used set of 9" wide slicks and ran a 12.20.. Even if you dont posi it atleas put some good tires on it. My friend has a open rear and he ran slicks and would burn the one alittle bit in the box then when he went on the track it was pretty much posi taking off. Im Thinking if you get some good tires you might be in the high 12's low 13's at around 105 mph
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
