Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
now what will i run?
Old Jun 18, 2009 | 11:14 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
alright ive asked this before but im going to do it again since now ive fixed all the little issues i had when i ran the car before. my last time at the track the best i ran in the 1/8 was a consistant 9.7 at around 77-78mph. the car was in horrible tune at the time. was way too rich at wot it had a stock converter and i found out later that the outer ring on my balancer had slipped so i had no clue what my timming was but it was also a tooth off. found out the throttle cable was too long too and was only allowing me to go 85-90% throttle. i have now since fixed all those issues and now have a 3500 stall. the car runs and pulls much better and definately launches a lot harder. im hoping to run in the high 8's after some tunning and if i can get ahold of some sticky tires.
Old Jun 19, 2009 | 06:36 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: now what will i run?
Need more info on the car, weight engine, trans, gears and induction would be a good start.
Old Jun 19, 2009 | 07:15 PM
Screamin86's Avatar
Sorry bout that my sig isnt too in deth on that car. Its a 82 ta hardtop no options prob 3300lbs give or take with me in it. 305 .030 flat tops 416heads with "z28" valve springs screw in studs and guide plates been shaved a little stock thickness headgaskets. Summit 1103 cam 214/224 442/465 @0.050 1.6 roller rockers edelbrock performer rpm intake edelbrock 1406 carb. Hedman lt headers into custom y.no cat with 3.5in i pipe then cutout rin over axle into stock 4thgen muffler. Th350 trans with shiftkit ******* performance 3500 stall(custom built for motor im building) ls1 alum. Driveshaft 3.73 gears 28spline axles eaton posi
Old Jun 19, 2009 | 08:27 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that combo should run some 8.6x's with a good 60'...
Old Jun 19, 2009 | 09:07 PM
Screamin86's Avatar
Thats kinda what im hoping. Last time out with it running horrible and no converter best i got was like 2.3x. Yeah mw66nova this motor was sorta a copy of the one you ran way back when lol. Now that everything is working well together and since the stall went in im in dire need of some tires. Selling the 17s this weekend hopefuly and the worn out 235 hoosiers on my 15s spin from a 20mph roll lol.
Old Jun 19, 2009 | 10:43 PM
mw66nova's Avatar
Engine: 7.0L
the combo is nearly identical to the one i had running 13.0x's. the only real differences i see is that i was running a 700r4 and a 650 double pumper...but my converter flashed to 4K.
Old Jun 20, 2009 | 01:17 AM
Screamin86's Avatar
Yup i remember that combo lol hopefully i can get close to the same results if not no biggie this motor is just here to get me around until the 383 is done and to get the car setup.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
