what will it run?
what will it run?
iv got an 86 camaro sc that will weigh around 3000lb on the line, heres my setup 60 over 350 with cast flatops,rpm airgap,750 holley ms,comp xe274h cam,3500 converter,th350,3.42,26'' drag radials,shorty headers,062 vortec heads cut for extra lift but oterwise stock, im only running the water pump and alternator. what do you guys think it will run?, i figure it should go mid 12s but i could be terribly wrong if you need to know anything else just ask thanks
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: what will it run?
Welcome, and mid twelves should be obtainable if the car weighs in at 3k. What cc heads? Compression?
the heads are stock 062 vortecs their supposed to be 64cc but iv read they vary between 61 and 64, the cr im not sure about but the pistons are 4 valve relief cast flat tops that may or may not have the.025 taken off there just a cheap piston i bought the short block from a guy that had all the machine work done and had already bought the pistons so i just used them i know its a shot in the dark without knowing the cr but im about 2 weeks away from getting it to the track and i was just curiuos what you guys think thank you
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
12s should be doable so long as the car is actually that light and everything is working properly. I imagine you're probably around 10:1 compression with that setup. any other suspension work?
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
