Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Who races with a stick???
Old Aug 31, 2009 | 05:00 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
Just wondering on what kind of hydraulic clutch setups you guys have and if it's worth the upgrade or who runs oem. I went through 2 centerforce df's this year and the hydraulics may be to blame. Clutch was setup, flywheel machined and broke in correctly. Car has prolly 450 hp and runs a 12.5 @113mph.
Is it worth all that money for mcleod hydraulics or should I just get the GM stuff?????
Could an air bubble have caused that spongee feeling that burned out my clutch on that last pass down the strip??
Old Aug 31, 2009 | 05:07 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
Re: Who races with a stick???
I only run stick i just prefer it. But i use the factory setup. As for your spongee pedal most likly an air bubble or your clutch master cly. is going out
Old Aug 31, 2009 | 07:17 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I run stock hyd. setup. I only run a stick in my cars. You need to see if you can bleed the hell out of the system.
Old Sep 1, 2009 | 02:40 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
i run all stock hydraulics with my car and have never had a problem, i did have a problem with a centerforce dual friction clutch when i first put the t-56 in my car, after that i used a AC Delco clutch kit and have yet to have a problem with it. another thing to consider if if your flywheel has been machined a couple of times, you might have to shim the flywheel back out since theres no adjustment for pedal height.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
ndndndnd
Sep 28, 2015 08:00 AM
