Got my frist 8 sec slip
Car: 91 Bird
Engine: Pontiac 500 + CID
Transmission: 3 speed auto
At the Cecil County RAM Race I went 8.80@156.52 MPH weight at the end of the run was 3540 lbs. Stock suspention, on a 275/60/15. 515 Pontiac N.A. with RPM Heads and Victor Intake.
Re: Got my frist 8 sec slip
8.80s @156 is gettin it done @ 35xx with a conventional headed single 4 barrel (if it's a 4150 i'll jock even harder) na motor, even if it is 500 somethin cubes. props for doin it on stock suspension and a 275
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Congrats man that is haulin the mail. Just wondering you said 275/60/15 which would mean probably a street radial right? The picture you posted doesnt look like a 275/60/15 street radial though. Just wondering what your 60 foots are on the 275/60/15. Congrats again though.
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Congrats man. I was there that day sitting on your trailer before you ran that time. I guess you like the hoosiers.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
also looks like more preload needs to be added to the anti-roll bar since it picked the tires up unevenly from that pic angle at least.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If I can ever get down to a sea level track, I might be able to get an 8 second timeslip. I could also throw a NOS system on my engine and do it at altitude
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Anyways, 8.80 seems very good for such a heavy car, over 3500lbs! My DD weighs 500lbs less then that!
Last edited by AlkyIROC; 10-01-2009 at 01:17 PM. Reason: moderator edited to remove quoted material
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Man, that is really haulin' it in a 3500 pound car!!!! Congrats on a really great pass!!!!
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Nice!!
Was that your first outing on the drag radial,and what was your psi set to ?
Good pic.
Good pic.
Car: 91 Bird
Car: '82 Camaro
Engine: 383
Car: 91 Bird
Yea, That was a LONG weekend! I think the Goodyears would work if I had put in more air. It would seem that a car this heavy you need a bit higher Air PSI (20+) The Air factor was 1400 ft that run. This was my frist full pass on the car with this motor. I am sure it will go better at some point. I am still learning what it will like. Ed Quay has been Huge in getting the car set up. The car only hit a 1.36 60 ft and just barley pulled the tires up. The car with the old 477 cid went 1.28 60 ft(9.19 @147.92 MPH only 3380 lbs) with a lot less HP....So I will be trying my best to chop away at the 60ft. I would think Mid 1.20's should be able to be had with the current set up. I have never run any of my cars up on a MT top But I know the NHRA has a factor they use to compare to sea (0.0 FT) Cecil is 347 Ft above. I am sure you can look it up. I was Just very happy that the 3 yrs of Building and planning actully all came together and Ran the E.T I had in mind and had a little extra MPH than I had thought. Thanks Guys!
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
Great job, and doing it on a stock type susp and reg ol drag radial. Thats a clean a$$ car too.
rb85TA
26
09-14-2015 10:29 PM
UltRoadWarrior9
09-02-2015 08:24 PM
