Blowshield
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Blowshield
Does anyone know if a TCI or B&M blowshield will fit under the floors of theses cars? I have a nice TCI one on my TH400 and I want to try and figure it out before I put it in the car. Anyone used one? Did it fit?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Blowshield
Transmission shield? I had a TCI on a TH400 in my car years ago.
I now use a powerglide. I had a CSR flexplate shield and TCI tranny shield but when they expired, I upgraded to a one piece CSR shield to do both jobs. It costs a little more than the typical steel plate shield but it's almost a form fit over the tranny for much better clearance issues. My clearance issues are just accessing the bellhousing bolts because the engine is pushed back slightly. I can't access the bolts from the top and I don't have a removable tranny tunnel yet. The CSR shield gives me the access that I need.
You can also use an inexpensive blanket shield if you want but they retain a lot of heat in the tranny.
Engine: 406sbc
Transmission: TH400
Re: Blowshield
Yeah I've got a J.W. ultrabell and a trans shield. I was just wondering if they even fit. I dont even need it for the times I'll run but whats a little added security since it comes with the trans.
