Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
? about 1/4 mile time
Old 01-31-2010, 11:04 AM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
I just bought a 87 z28 with a 430 horse power 70 or 71 350 in it the motor has a cam 202 heads 650 holley double pump carb and for the trans i have a turbo 350 backed up by a 2000 stall and a stage 2 shift kit . my rear gears are 411 and it is a 12 bolt posi unit. ?what 1/4 miles times should i get with my set up with a good launch??? any guess just wondering
Old 01-31-2010, 11:24 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: ? about 1/4 mile time
I imagine with a good launch it's in the area of a 12.2...
Old 02-07-2010, 09:32 PM
Dennis79Formula's Avatar
Car: 1979 Pontiac Firebird Formula
Engine: 355 Chevy
Transmission: Turbo 350
whats the cam specs? what pistons? what comp ratio? if the motor isnt matched it could be a terd but if everything is put together right and matches she could fly
Old 02-08-2010, 10:20 AM
Car: 87z28
Engine: 70 LT1
the pistons are 11to1 dome pistons with 202 heads a holley 650 double pump carb . i believe the cam is the 290 cam ''lopey idle'' with a 2000 stall converter backed up with a 12 bolt rear end with 411 gears. the motor had over 325 horse power before all the work was done on it. I was just looking to see what it would run in the quarter mile i know when i tap on the gass it wants to lift the front end . so i know the power is their. what size tires can i fit on the back for traction? the guy i bought the car from said the motor had over 430 horsepower. which isnt hard to get with the 70 and 71 350 4 bolts. ? let me know what u think
I know iam gonna get bad gas mileage but who cares. iam driving one bad *** third gen lol.
Old 02-08-2010, 06:55 PM
Engine: 355 Chevy
if its the comp 290 cam or is it 292 i cant remember but anyway that motor should fly im thinking anywhere from 11.90 to 12.20
Old 02-10-2010, 09:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
You prolly got crap heads, and that stall is just about at the stock level...
Mid to high 13s but it's impossible to guess really...
Old 03-09-2010, 12:21 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
that converter is stalled way to low for your combo. Maybe in the 3000-3500 would be much better. Let us know what time you run at the track
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
evilstuie
01-09-2020 08:29 PM
Andrew6.688
12-13-2015 10:59 AM
Derick15
Members Camaros
08-20-2015 10:19 AM
Quick Reply: ? about 1/4 mile time
