Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
auto-x 89 Trans Am
Old Mar 30, 2010 | 01:46 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
auto-x 89 Trans Am
Ran in auto-x last sunday. have a stock 98 ls1 swap with 4l60e and early 4th gen rear with 3.23 gears. I am running in FS because it is a local event and the only other third gen is a 1le car with konis. Currently the car seem to be very tail happy and with auto if it kicks to first gear it equals an automatic wheel spin. Tires are old worn out 710's . Just wondering if anybody can suggest on what can i do to make it little less tail happy and stop the massive body roll.
results:
final
raw
pictures:
Old Mar 30, 2010 | 07:47 AM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Re: auto-x 89 Trans Am
anti roll bars, different suspension, springs
Old Apr 4, 2010 | 10:25 PM
Midniteson2's Avatar
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Try swapping in a smaller rear sway bar from a base model camaro or firebird. that should keep the tail from stepping out. poly bushings and good shocks/struts help a lot.
Old Apr 4, 2010 | 10:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
looks good. what do you have for suspension now?
Old Apr 5, 2010 | 07:30 AM
Car: numerous
Engine: ls1, others
suspension is stock ws6, new sway bar endlinks upfront and subframe connectors. Actually in the rear i am currently using a fourth gen sway bar, if it is larger than my stock one i will try putting the stock one back on before next auto-x.
Old Apr 5, 2010 | 11:54 AM
Car: 1991 Firebird
Im not sure the diamater of the 4thgen rear bars, but your stock WS6 rear bar should be 24mm, which is the biggest rear bar you could get from 82-92. I would hit up a junkyard with a caliper that measures mm. the rear bars vary in sizes from 19mm, 21mm ,23mm and 24mm. the bigger the rear bar the more the rear will step out from my experience. if you can snag a couple rear bars from the boneyard in different smaller sizes, you can swap them on easily and figure out which bar makes your car handle the way you like for very cheap. I like the 24mm bar but i like to steer around corners with the throttle, and have about half the power you have lol. Very nice Trans AM!
Old Apr 26, 2010 | 09:51 AM
Car: numerous
Engine: ls1, others
it appears that the fourth gen bar is actually smaller. Went to another auto-x even yesterday and got few videos. Need a driver mod.
http://www.youtube.com/watch?v=L0VREVL4Dl8
http://www.youtube.com/watch?v=Z6skE5sBnR0
Frozer!!!
Jan 19, 2024 04:55 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
