Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What will i run?
Old Mar 31, 2010 | 03:58 PM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
What will i run?
Like the title says i want to know what my car will run in the 1/4.
Modifications:
3.43 posi rear end
xe262 comp cam with pushrods/rockerarms
Built th-350 transmission with shift kit (transpak)
edelbrock dual plane intake (non highrise with egr blocked off)
headers (with only a high flo cat with stock exhaust)
HEI ignition
650cfm edelbrock carburator
Also all the emissions are off the car.
I dont expect much but i just want to see what i can possibly get.
Old Mar 31, 2010 | 04:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What will i run?
Low 15's, maybe high 14's. It is only a 305.
A guess is just a guess. If you really want to know what it will run, you need to take it to a track. Until then, any wild guess is as accurate as you're going to get.
Old Mar 31, 2010 | 04:45 PM
1970 Buick's Avatar
Car: 1989 GTA
I would say those mods put it close to a stock 350. Maybe a 14.8. Just a guess though.
Old Mar 31, 2010 | 08:11 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Probably low 15's high 14's until you help your motor breath better by getting rid of your cats and getting a dual exhaust
Old Mar 31, 2010 | 09:44 PM
anthony714's Avatar
id agree.them mods on a smaller older engine amount to a 350.if it hits high 14s be happy.dont expect much. youll be lucky if youre even near 350 hp,more like 300 on a good day and 300-350 hp (gross) doesnt translate into very quick et.just simple math. maximize your fun,no its not a burner but join a bracket racing circuit. it doesnt matter how fast you are,its all handicapped and as long as you have quick consistent reaction times youll do ok and have a blast doing it. nothign like beatng a 10 second car in your 15 second car........
Old Mar 31, 2010 | 10:24 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
That's kinda similar to my old 305 that has: 600cfm Edelbrock, Performer RPM(non-air gap), 204/214 .420/.442 cam, headers, no emissions, HEI, and it runs 14.4's. Granted I don't really use it since I have a much better motor, but it still hangs around waiting for the next time I blow something up. What's even cooler is that I was messing around one time and put the big turbo on it with 13psi and it ran a 12.2 pulling a wheelie without any spooling issues.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
