Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Window Net Install Help
Old Apr 13, 2011 | 04:25 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I was wondering for those of you with a full roll cage, how did you incorporate the window net into the cage and what mounts etc did you use? Pic would be EXTREMELY helpful, thanks!
Old Apr 13, 2011 | 05:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Window Net Install Help
The bottom mount is through a slip tube at the rear. The front of the bottom is spring loaded so when I pull it up to latch the seat belt connector at the top, it pulls the net tight.
The upper mount is solid mounted at the rear with a rod end so when unlatched, it swings down out of the way.
The seatbelt latch needs to be on the inside of the roll bar tubing.
Old Apr 17, 2011 | 10:13 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I like the spring incorporation, good idea
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
bryan623
Aug 10, 2015 11:33 AM
