Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
a new look
Old Feb 10, 2013 | 09:56 PM
  #101
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: a new look
Just be sure to use aftermarket improved parts. My stock Ford 9" caps exploded and ruined everything in the diff...and that was just with a stock internal LS1 and stiff wall slicks. (4.11 gears)
Also, I'm not really sure in the real world the power loss of the 9" is significant enough to even matter. My best trap was 116 which is pretty dang good given only bolt ons with the LS.
Old Feb 11, 2013 | 07:06 AM
  #102
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: a new look
yup. i'm running a stock nodular case with billet caps, so hopefully that won't happen...but the six speed is a new venture, and that case has probably 1000+ passes, all faster than 1.60 sixty. only a matter of time before i'm looking for a thru bolt case.
Old Feb 11, 2013 | 11:28 AM
  #103
DIGGLER's Avatar
Re: a new look
i have a moser aluminum thru bolt case with less than 50 passes on it. i'll sell it for $300. it has 3.062" bearings, and i am going to have to move up to the 3.25" case for the new spool/axles.
Old Feb 11, 2013 | 11:46 AM
  #104
mw66nova's Avatar
Engine: 7.0L
Re: a new look
that's a killer deal. i'll let ya know if i can do that.
Old Feb 11, 2013 | 01:54 PM
  #105
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: a new look
I found this a while back at BIG_MODS' website. Was pretty interesting I thought...
Old Feb 11, 2013 | 02:10 PM
  #106
mw66nova's Avatar
Engine: 7.0L
Re: a new look
i really don't like that they didn't use the same gear ratio stock to 9"/s60 for that comparison....
Old Feb 11, 2013 | 08:07 PM
  #107
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: a new look
I have a couple problems with that comparison. First they only compared peak horsepower/torque numbers, I would rather see the whole graph. Second if both the stock rear and a 9" are both in motion it takes very little power to keep it moving at that same speed. I'm more concerned in the rate of acceleration loss becaus that's where the real comparison is. They would have had to use the same car and same conditions to be a more accurate test. If you take the same rear out of a 12 second car and put it into a 9 second car you will see a lot more power loss in the second car even though nothin changed in the rear, your just trying to move the same weight at a lot higher rate of acelleration.
Old Feb 11, 2013 | 11:33 PM
  #108
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: a new look
a magazine did a test a few years ago with converting for weather conditions over the course of a day and ran a 12 bolt, 9" and dana 60 and they all were within .08 of each other in a 10 second car.
Old Feb 12, 2013 | 01:01 PM
  #109
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: a new look
That would be a cool read. Can we find it?
Old Feb 12, 2013 | 02:10 PM
  #110
xpndbl3's Avatar
Car: 1984 Z28
Re: a new look
Hot rod did it a few years ago. 12 bolt and 9" were really close. Dana was the slowest from what I remember
Old Feb 12, 2013 | 03:47 PM
  #111
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: a new look
oh your case failed nicely. mine exploded into 19 pieces. ill have to find pics. took out my driveshaft, yoke, broke my tranny and neeed new bearings in my converter too.
Old Feb 12, 2013 | 09:18 PM
  #112
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: a new look
I remember the 12v9vs60 and it was nice to see them use the same car.
Old Feb 13, 2013 | 07:25 AM
  #113
Shagwell's Avatar
Car: projects.......
Re: a new look
Yep. Until you get into the high end class racing where every .01 really matters, all the trick/ultra-light drivetrain stuff really doesn't make a noticeable difference.
I've actually run all three rears(60, 12-bolt & 9"), if the 12 ever fails me in the Camaro I will likely go to an S60 simply from a cost-vs-strength stand-point. - Depending on which engine combo & class we often have to run some ballast any way, thus it doesn't matter much.
