Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
what will i run
Old May 16, 2011 | 05:12 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
what will i run
i was hoping to get an idea of what i will run on the 1/4 and 1/8 mile drag strips.i have a 1985 z28 with a 383 stroker,roller rockers,camel hump heads,electric fan,full length headers,accel super coil with the plugs and wires and a summit racing 600 cfm carb that is all i know about the engine.tremec tko 600 tranny and stock rear end with good year 28x10.5-15 drag slicks.my next question is what would be a better rear end for street and strip a 3.73 or 4.11 or something else.i know the driver has alot to do with times just want an idea
Old May 16, 2011 | 06:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by stroken85z
...my next question is what would be a better rear end for street and strip...
Anything.
Don't even consider putting different gears in the stock rear end. My first thought of a response to your ET question was, "Low-13's - once."
You need a 9", 12-bolt, or S-60 in there with 4.56 or higher gears, depending upon the details of your cam. Probably need a bigger carb as well. Hope you have about $2500 laying around.
Old May 17, 2011 | 06:47 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: what will i run
600cfm on a 383?
what's the cam size? what head casting number? "camel hump" is a vague concept as those cylinder heads had a lot of options. some of them were OK for their time, some of them were duds though.
at the moment, i'm going to agree with five7kid, mid/low 13's once or twice before the stock 7.5" 10 bolt explodes
Old May 17, 2011 | 07:56 AM
stroken85z's Avatar
Re: what will i run
what would be the easiest rearend to swap as i dont have any welding exp.how about the 4th gen rears.where would the casting number be,what size carb should i be using
Old May 17, 2011 | 10:08 AM
mw66nova's Avatar
Engine: 7.0L
Re: what will i run
casting number on the cylinder heads will be in the rocker valley.
fourthgen rearends are the same weak 10 bolt we use. they have 28 spline axles, but are wider and require fourthgen offset wheels. look at a Moser 9" for a bolt in ordeal.
carb size depends on the whole package. cam size/intake manifold/cylinderhead/ compression/and shift rpm. but i would imagine a 750 would be a bit better suited for even a mild 383.
Old May 17, 2011 | 01:31 PM
stroken85z's Avatar
Re: what will i run
ok iwill get the casting number anyway i can check the cam without removing it.it has an edelbrock rpm airgap
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
