Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Anyone have a th-400 with a CSR shield?
Old Oct 28, 2011 | 12:16 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I'm planning on switching over to a th-400 this winter. I currently have a th-350 with a csr shield and it fits pretty well. Its tight but fits well. The bellhousing bolts are very close to the firewall so I have to pull the engine and trans together, other than that its no problem.
I hoping a th-400 with a CSR shield will fit just as well as my th-350? I'm hoping not to have to do any trans tunnel modifications. Any suggestions would be greatly appreciated.
Old Oct 28, 2011 | 11:22 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Anyone have a th-400 with a CSR shield?
i just had an ultra bell installed and then you don't double up on the case and shield thicknesses. Mark your firewall for where the bellhousing bolts are at and next time you pull it, dimple the firewall 1/2" or so and you'll have plenty of clearance.
Old Oct 29, 2011 | 07:29 AM
jbenge's Avatar
So do you also use a blanket to cover the top of the trans? I was wondering what is more trouble the csr shield or a ultrabell and blanket. Using a trans blanket on the street would probably retain a lot of heat?
Old Oct 29, 2011 | 09:43 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I had no clearance issues with a th400 and CSR shield. I just unstalled the supplied bolts into the shield before lifting the trans in.
Old Oct 29, 2011 | 07:39 PM
xpndbl3's Avatar
Car: 1984 Z28
i use that TCI drum shield, it's blue in color made out of aluminum I believe.
Old Oct 29, 2011 | 09:56 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i gots no shield. tried a blanket and burnt it up on the exhaust in 3 miles. i should probably do something about that...
sailtexas186548
Feb 17, 2017 03:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Genopsyde
Nov 11, 2015 10:46 PM
mustangman65_79
Sep 1, 2015 03:51 PM
kyle5647
Aug 15, 2015 11:56 PM
