Estimate my 1/4 ET
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Estimate my 1/4 ET
91 Firebird Vert
87 MAF L98
Ported Plenum
Ported SLP Runners
TPIS Lower Intake
Crane 2032
Stock Heads
MSD Distributor
Hooker 2055 Headers and Y pipe
Magnaflow 3" exhaust
700R4 2500 Stall
3.45 9 bolt Posi
Subframe connectors
Founders rear control arms and panhard bar
Billstein rear shocks KYB front struts
WS6 wheels 245/50/R16 Firestone Firehawk INDY 500 Tires
kinda hoping for 13.5
what you think?
87 MAF L98
Ported Plenum
Ported SLP Runners
TPIS Lower Intake
Crane 2032
Stock Heads
MSD Distributor
700R4 2500 Stall
3.45 9 bolt Posi
Subframe connectors
what you think?
Engine: 5.7 L98
Re: Estimate my 1/4 ET
oh man, ill be so pissed if i cant get into the 13's
91 Firebird Vert
87 MAF L98
Ported Plenum
Ported SLP Runners
TPIS Lower Intake
Crane 2032
Stock Heads
MSD Distributor
700R4 2500 Stall
3.45 9 bolt Posi
Subframe connectors
what you think?
87 MAF L98
Ported Plenum
Ported SLP Runners
TPIS Lower Intake
Crane 2032
Stock Heads
MSD Distributor
700R4 2500 Stall
3.45 9 bolt Posi
Subframe connectors
what you think?
Engine: 5.7 L98
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Engine: 5.7 L98
if this car cant get into the 13's im gonna puke... then have to buy a supercharger
Engine: 5.7 L98
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by insomniac
Crane 2032 & Stock Heads
Engine: 5.7 L98
Whats a "RV" cam?
Duration @ .050": 214/220
Advertised Duration: 270/276
Lobe Separation: 112
Gross Lift: .452/.465
Basic RPM Range: 2000-5500
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i think it can go 13.9's given optimal conditions. what's the DA typically where you race at? also, what is the weight of the car? Orr89Iroc went 13's with a bolt on and converterd l98 car
Engine: 5.7 L98
Car: 89 Formula 350
Engine: 5.7 L98
13.2 thats really good. what bolt ons did it have?
Car: 89 Formula 350
http://www.gmhightechperformance.com...s/viewall.html
Its was 98* at Englishtown when everyone ran these times. I ran the the 13.20s in much cooler weather
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
I believe you have a 13 sec pass in it.
My 91 Camaro. Full weight with street tires ran 13.96@ 90sumthing.
Stock l98 speed density 350. 150,000 mile engine. K&n filters. Full msd ignition and a jet chip.
RedLeader289
May 28, 2019 01:47 PM
