LSX LQ4 1/4 guesses?
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Hey guys, My cars almost done and I currently have a 6 point cage in my car and need to know what else I will need to be ready for the track so what do you think it will run.
1984 88 Formula clone
LQ4 370ci 480 rwhp
LS3 heads
Custom big LS3 cam
Hawks 1 7/8" headers
4l80 with brake and 4500 stall
Moser 9" 4.30 gear
28" slicks
Car weights 3200 with me in it.
What do you think it will run?I also have nitrous on it. What do you think it will run if I hit it with the 150 shot?Thanks,Dustin
LQ4 370ci 480 rwhp
LS3 heads
Custom big LS3 cam
Moser 9" 4.30 gear
28" slicks
Engine: 370 LSX
Re: LSX LQ4 1/4 guesses?
That would only be 8.89-9.2 in the 1/4 if I am reading right.
Engine: 370 LSX
Mid 10s haha. Look like I need more bars in the car.
Engine: 370 LSX
I wasnt really worried about how fast it went I just wanted it to pull the wheel(s). I have v6 springs up front with Competition engineering adjustable drag shocks in the front, v6 springs in the rear with adjustable competition engineering shocks in the rear, SFC, Lakewood LCA, Adjustable Panhard bar, and the jegs tunnel mount torque arm.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Engine: 370 LSX
Engine: 7.0L
i second having too much gear for the 1/4 though, with the spray. i was going through the traps at 6400rpm's with my 4.11's. i just got some 4.30's to put me through the traps at ~6700rpms, which is where i shift at. this is for my n/a 370 with less cylinder head than you have. i'd imagine you'd go through the traps at 6900ish on motor. i think your setup will be good for 10.6's before the 150 shot. the 150 shot will probably put you in the 9.7 range.
Engine: 370 LSX
The 4.30 cam in the car when I bought the moser 9". I figured I may be ok with them since it's a 4 speed tranny. What if I go to a little taller tire?
The motor is actually built for a 250 hp hit of nitrous, but I figured 150 would suffice.
Can anyone tell me when a 6 point cage is no longer enough. I can't find it.
well, mine makes around 425 on motor, and with a 100 shot it runs 6.10. with a 150ish shot it goes 6.00's. somewhere around 3050-3100lbs. if he fixed the gear and converter and got the 60's in the 1.3's i think it would be doable.
Engine: 370 LSX
What converter? Is my stall to high?
Engine: 7.0L
you need to answer a question right now: do you want it fast on the bottle, or do you want it fast NA. that will determine your next steps
Engine: 370 LSX
Both haha. I want it fast on motor cause it's gonna be a street car 80% of the time. The nitrous probably won't be used a ton, but when I use it I wanna go really fast.
Engine: 370 LSX
Who makes a 4l80 nitrous converter in a 4500 stall
call greg at FTI. i think he's done a good bit of 4l80 converters. dont ask for a stall speed, tell him what youve got. actually, you need to fill out a sheet with all your engine info and stuff so you can send that to him. stall speed will be lower, like 3500ish. look to spend around 900-1200 for one. (maybe more if you retain the lockup ability?)
Engine: 370 LSX
Yea, maybe I will only get to run 1 sub 9 second pass.
Engine: 370 LSX
Orded a new converter today. I got a 4300 nitrous converter on the way. I also Purchased the down bars and cut and chopped them till everything fit right and im going to weld them up tomarrow.
Engine: 7.0L
pics of the bars? i always like looking at other peoples renditions of roll cages, so i can get ideas of what i like and what i don't like
Engine: 370 LSX
Engine: 370 LSX
No its a Jegster 4 point. I installed it. Total pita by the way. The kit is seriously about 2 feet too long on the main hoop. The door bars I just bought some steel I needed and went to town with my bender, chop saw, notcher, grinder and tig welder haha. Im going to go ahead and make it a 10 point so I will be good till 8.50 after inspection and my license.
Car: 85 IROC-Z
Engine: 355 SBC
Transmission: Powerglide
Axle/Gears: Moser 35 spline w/ 4.56 gears
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
any of them will work, just make sure you buy them for a moser housing. THEEEE best one with the most adjustability are the racecraft ones with like 9 holes on them, but they are the most expensive and you'd cut off the entire LCA mount and weld theirs on. The typical choice is the 3 hole ones that UMI, BMR, spohn, etc all sell the same thing and you weld them to the bottom of your stock LCA so no issues with alignment.
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Also call trz they have some that you can replace your original mounts with with like 9 holes. Cheaper to boot.
Engine: 370 LSX
I got some new stuff done on the bird recently.New gauges are in the dash and in the car now.
I got the new tires and wheels mounted too.
Engine: 370 LSX
Engine: 370 LSX
Are my pictures showing up all jacked up or is it just this work pc?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Nice work man, my car is 3150 without me in, makes me want to do a firebird honestly.
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
I'd like to get myself a bird....I already have 2 cars though. Love the no gfx cars!
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I like camaros with GFX, birds either way, Matt is the only one to pull of a no GFX car that i like.
Transmission: 4L80E/4L80E
Car: 1988 Iroc-Z Black w/ blue/silver
Engine: L98 5.7
Transmission: 700R4 (obviously)
Axle/Gears: BW 9-bolt 2.77
Agreed. That black Camaro with no GFX does look pretty sick but i bet id still like it a little better if it was all decked out with the Iroc or Z28 stuff. Firebirds can pull it off better somehow, idk why lol. Id love to do an LQ4/T56 swap at some point, just cant bring myself to butcher such a well documented car >_< damn me and my sentiment hahaha
Car: 1987 IROC
Engine: 350 vortec
not mine, but one of my all time favorite cars, Jeff Moyer's drag radial car. haven't seen him around here in a while though, goes by radialtireking most places.
Engine: 370 LSX
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
LOL, Looks like the beater third gens i see from the hood.
Find a rolling body and do it to it!
You pull it off my friend.
Not ugly, but matts being white with black here and there, just makes it work for some reason.
Close enough...
It's kind of fun to see the new paint, pizza-cutter fronts, big-tach shift light, stripped interior, race seat, roll bar cars in the staging lanes with you, and know you outrun them by a second or better.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Oh yea, my shoddy paint has surprised plenty on the street and track. But that think looks like the old v6 or 305 car on its last leg.
Engine: 7.0L
i tell ya what, i love having my full interior and all the street equipment, and pulling up to a car that's completely gutted. though i fit most of the rest of your description (except the slower part)
Engine: 370 LSX
I got some more work done on Friday night. I didn't come into the house till about 4 am, Made for a long day considering I had been up for over 2 days since I work 3rd shift.
I pulled the Trick springs and cut 1 full coil off each side lowering it about 2". It still has a ton of ground clearance on it.
Yes, that is a stock hood. I have a Victor jr and a big carb. I have about 2" of space between the carb and the hood for anyone that things that it will never work. I saved myself $550 by trying to put it on even though everyone said know way. I couldn't even begin to tell you how happy I was that it all fit.
