Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
T56 issues baack apart - and bell housing dowels suck to remove
Old Jan 28, 2012 | 04:16 PM
87_TA's Avatar
Started having issues with the T56 not going into 5th and 6th only, called liberty they blamed disengagement which I know is not the issues..
Sent back and they said I showed a big TIP Load on the input shaft likely from Bell alignment..
The Mcload bell housings are all supposed to be pre checked and do not need verified - and before anyone calls me stupid - You can not check without tearing into trans due to bell being fully open on trans side.. So liberty sends back the faceplate of trans - I find that it was sitting .027 low and Squarness was about .020 off as well also driving input shaft down even farther!
I have fixed squarness and awaiting offset dowls to fix off center, removing the SHP dowels were horrible to remove - one I could access from front of motor and had to hoss on with a 2lb sledge for several minutes - the other was not so easy - drilled several holes through (and even drilling into block - awesome) still unable to budge with huge channel locks - Had to weld a bolt to my slide hammer then into dowel to finally get..
Not sure if it is the SHP block or McLoad bell that caused the issues, I am assuming the bell - It in turn cracks input shaft tube and ruined bearing - not sure what else at this point - 1st through 4th still felt great.. Also while tearing apart found balancer sheared the key - More awesome!
Old Jan 30, 2012 | 06:11 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: T56 issues baack apart - and bell housing dowels suck to remove
welcome to having a FAST t56 car...not that i know much about it, lol. good luck with it dude, hope the upgrades fix it and you don't have many more issues.
Old Jan 31, 2012 | 10:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
With any performance bell you need to check it for squarness and runout !
I have even found the factory stuff can be off a bit. Best to check them all really!
Old Jan 31, 2012 | 10:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
That sucks man, but yep, fast T56 cars I hear are a pita to deal with.
Old Jan 31, 2012 | 11:02 PM
87_TA's Avatar
Yeah it kinda is. Should be ok after this I think, hope the 12 bolt holds up though...
TT350: true. But like I said mcload says no need and trans needed to be apart to check being bell is wide open w no referance points.
Will not make that mistake again! But even trying to use the flat trans mounting surface to check square. That thing had .010 with just a one one inch move of dial.
While back at liberty upgrading to 30 spline output to keep that out of back of my mind
Old Feb 1, 2012 | 06:50 AM
Shagwell's Avatar
Car: projects.......
^ and the shrapnel from the little yoke out of your butt cheek........lol
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
