Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
need posi traction
Old Sep 12, 2000 | 03:33 PM
85ZZ4TPI's Avatar
need posi traction
I am running my stock 323 geared ten bolt one wheel wonder and I want to go to the track before winter, I am considering installing a mini spool or just weld it together? No Cash to do it right! Any suggestions?
Old Sep 12, 2000 | 07:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you don't want to install a posi, summit now offers a mini spool for the 26 spline axles. Nobody offers a 28 spine mini spool yet. There are no full spools available for the 7.5 diff either.
If you are going to get it welded, find someone who will heat treat the carrier and weld it with stainless rod. Anything less won't hold.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
