Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
SSM part# 1316 ?
Old Sep 20, 2000 | 12:38 PM
James406Camaro's Avatar
SSM part# 1316 ?
Does anyone have this kit? That is the kit with sfc's, crossmember, lift bars, driveshaft loop and all reinforcements.
How does it work? Quality pieces? Worth the money? Any info would be appreciated!
James
85 camaro, 406 sbc, 5.7 rods, Sportsman II heads, Edel. Performer RPM intake, Isky 270 221@.050 .465lift 108sep, Crane Rollers 1.5 7/16, SLP 13/4 headers, TH-350, TCI Breakaway, MSD Pro-Billet distributor, AIS Ram Air Box, 295BFG's on Convo Pros @ rear
Old Sep 24, 2000 | 05:50 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I have that SSM kit. The subframe connectors fit great, I never got around to installing the driveshaft loop. One problem I have is that the crossmember is very low. It drops in the center to clear the driveshaft. I was considering cutting it back out of the car and inverting it so the notch sticks up (I'll have to notch the floorpans). I have bottomed the crossmember out on several occasions during normal driving. As for traction improvement- I can't tell you first hand. My car rolls on 17" tires that get no grip until 2nd gear & I haven't put slicks on yet... I'm putting in a 9" Ford rear first (another advantage of the kit is you no longer use the torque arm so if you change rearends you don't need one with the mount for it). I have heard of guys getting 1.5 60 ft times with this setup though.
1983 Firebird w/91 look
383 sbc, TH350 w/2800 stall, Ford 9" coming...
BumpaD82
Feb 26, 2016 02:57 PM
jtwoods4
Sep 3, 2015 10:19 AM
Jer82Z28
Aftermarket Product Review
Nov 27, 2001 02:11 AM
jag
Carburetors
Oct 29, 2001 02:44 AM
theformula
Oct 17, 2000 10:07 AM
