What will my car run?
Over the spring time I will be getting some major work done on my iroc... Here is what it will consist of:
A 350ZZ4 crate engine with the following:
-Moley Pushrods
-Crane Gold Series Roller Rockers 1.6 ratio
-Steel crank
-Forged Pistons (and one extra set thrown in)
-Edelbrock Valve Covers Polished Signiture Series (with the black
highlights)
-Complete Lingenfelter Intake Setup
-Lingenfelter Super Ram box full polsihed and ported
-heads are port matched
-lower TPI intake is fully ported and polished
-22lb fuel injectors
Keep in mind a stock 350ZZ4 is rated at 350hp and 405ftlbs
On the tranny I have a 3000rpm stall, shift kit, corvette servo, tranny cooler,its a 700R4 automatic. The rear end is 3.42 posi...
So my main question is what do you guys think this car will run when I get it back in the spring time (****ty canadian weather).
Thanx
-Moley Pushrods
-Steel crank
highlights)
Thanx
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
high 12s
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
Car: 84 Z28 Camaro
Engine: 350ci
All depends on traction !
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Tom K.
1992 Trans Am
Aug 8, 2015 08:16 PM
