Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Dyno Numbers
Old Nov 21, 2000 | 12:35 PM
SeanSullivan's Avatar
Dyno Numbers
Sorry, I know this isnt a brag board but thought some might interested in this.
Baseline Stock 305 w/tbi;
140 HP
Today's Dyno Run 5 1/4* advanced timing.
Top Speed = 170.3 @ 3800 RPM
5th gear 38.52 seconds.
Top HP = 188.6 @ 5500 RPM 4th gear.
Top Torq = 333.2 @ 5500 RPM 4th gear.
Eng HP est= 230.3 @ 5500 RPM 4th gear.
Current engine setup;
Open Element, K&N filter
Carter600cfm w/ 750 jets
Performer Intake
1.6:1 Magnun Roller Rockers
Hooker Shortie Headers
2 1/2 exhaust, hollow CAT, full boar muffler
Under drive pulley kit
Aluminum driveshaft
3.42 Limited slip rear gear
Dyno run done at PowerHouse Performance, MidWest City, OK
Old Nov 22, 2000 | 08:27 AM
JE$TERsn95's Avatar
Nice improvements
I went to the LS1.com dyno day here a while back with my Mustang to get a base line before I put the new motor in.
not trying to steal your thunder here, but figured I would share....
100% stock 1995 Mustang GT 5.0
146,000 miles has not been tuned up since 80,000 miles.
My best pull was RWHP: 192.7 TQ: 263.6
All of the LS1s pulled 300 RWHP and up....some were 100% stock, and a few were lightly modded.
Their was one C5 Vett that "only" pulled 298 RWHP....till he sprayed it and ran WELL over 400 RWHP
Dyno day was at Atlanta Chase Dyno
Old Nov 22, 2000 | 10:45 AM
Jester,
Very good numbers for stock. Found my 350, gets an extreme cam, 1.6 rockers, light weight fly wheel, before installation. That'll happen in two weeks. Then I'll go back to the dyno, and see what grand changes there are, I hope. Expecting to get a LOT more torque, hopefully another 75 to 100hp, but we'll see on that. I'll post when the new numbers come in.
Old Nov 22, 2000 | 08:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A ford 5.0 will always be better than a chev 5.0. They're totally differently designed engines. The 305 isn't designed for that kind of power. Now if the chev engine was the old 302 with the 4" bore it would be equal to, if not better than the ford version. At least it would be a better comparrison.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 23, 2000 | 09:02 AM
stephen, thats somewhat understandable. However, in this case the car gets a 350 in two weeks. the carb will change from the carter to edelbrock 1406, and the intake will change from performer to weiand. I'll do another dyno run then, just to see the differences. should be lots better.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
