How much power is my engine makeing?-part 2-cam specs
Here are my cam specs since i didn't include them in my first post.-Lobe seperation-116.-Advertised duration-292int,288exh.-Duration at 50-224int,-224exh.Valve lift-450int,460exh. Roshambo,Thanks for putting in my engine specs on your desk-top dyno,If you could re-do it again with the cam specs I've provided,I would really appreciate it.Thanks!
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
