V6 Springs for Drag?????
i was talking to a friend of mine with a mustang(yes i know) and he said that one of the hot cheap setups for drag was to put v6 springs in the back and 4cyl springs in the front. has anyone ever tried this on our cars? does anyone think it will work?
thanks
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
thanks
tim
14.301 @ 94.39mph
i did it, plus air bags, ce adjustable shocks, and lakewood drag struts. my car was 2.8 to start with so it wasn't much trouble going with the v6 parts.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
I have V6 springs on the front of my car and they really made a difference in weight transfer. My rear springs are from a standard 305 TBI firebird(comparable to an RS)
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Yes the rear springs have the same rate. There is no difference between the V6 and the V8 rears. The difference in the front is that the V6 is lighter, so the rates are lower. So the rears don't even matter.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
