Launches
Launches
My launche suck, 50% cause of My lack of traction, and 50% cause of my lack of experiance.
Firstly, How do you suggest launching, Stall up prior or just go from dead stop ?
full throttle or ease it in ?
and secondly, Is going out and repeatedly practicing my launches going to adversly effect my car ?
As Cool as it is to leave the line in a scream of burning rubber and blue smoke, Its better to Actually Put the power to the road.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Tires are the biggest part of getting good traction. Invest in some drag radials or slicks if you want to get serious about traction. If you want to keep your regular tires then you need to do some practicing. When you launch ease into the throttle just enough to where you lauch hard but don't spin much. Once you get moving then go full throttle. Takes a little practice to experiment and figure out what works best for your car. The practice is hard on your car but if you stay under your red line and don't spin at high rpm's for extended amounts of time then you shouldn't have too many problems.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
M/T ET street tires
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
My experience says that shifting manually is best for my car. But, then again, I know how to drive it. I'd say, you may be best leaving it in drive. This way you might be able to mash the throttle off the line w/out getting wheel spin. I've spoken to people before who swear that their cars are faster in drive. I can't see how that is, but it seems the guys w/ cars that are closer to stock are saying it. It's either their lack of experience/skills or maybe, for some reason, the car actually does run better that way.
Justin 87 GTA--organizer: "NY2K" Gathering. Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
[This message has been edited by Justin 87 GTA (edited January 11, 2001).]
Well, I manually shift 2-3 But 1-2 I cant because my shifter slips to 3rd, its the stock one and its not very well designed.
I think slicks are a little overkill, as Im running an internally stock LG4, but Im working on getting better tires here, the ones i have Do suck bad.
LCA's are also on the To Do list. But I guess what im gonna have to do is get out and practice. Thanks For the advice guys.
darwinprice
17
Oct 11, 2015 11:51 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
