Primary chassie mods to do?
I have a -84 Trans AM HO with no chassie mods. Whats the Primary chassie modifications i should do? I dont want to use 90/10 shocks, i want to be able to use it on the street to
So what should i do?
Bigsweed
So what should i do?Bigsweed
rear control arm relocator brackets are good to do. some upgraded control arms, panhard bar, and torque arm will help the car get out better. i use the spohn stuff, it works great, if you don't want to spend that kind of cash you can just find someone who welds and have them box the factory units for pretty cheap. even if you don't want 90/10's in the front you may want to put 50/50's in the rear. they will better control the movement of the car during launch.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
lata
tim
14.301 @ 94.39mph
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
First thing you should do is get some weld-in subframe connectors. That alone is a big improvement. After that, work on suspension. My race car still has stock springs and struts/shocks and ran well. If I had 90/10 front struts I probably could have picked up a few more tenths.
Change every rear suspension component. Stock factory parts are too flimsy and flexable. Anything in a suspension that moves and isn't supposed to, is lost energy that can be put to the ground.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
at your next local swap meet, look for a set of skinnies for the front. some 15x3.5 rims with pep boys tires on them can be a cheap way to pick up a couple tenths. also look for anything you don't need in the car and ditch it.
lata
tim
14.301 @ 94.39mph
Check Out The East Coast F-Body Nationals Home Page
<A HREF="http://www.geocities.com/njspeeder" TARGET=_blank>
[URL=http://www.mycar.net/mafb/registry/detail.cfm?id=299]http://www.mycar.net/mafb/registry/detail.cfm?id=299</A>
lata
tim
14.301 @ 94.39mph
darwinprice
17
Oct 11, 2015 11:51 PM
