Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Ultimatesuspension
Old Mar 28, 2001 | 10:12 PM
LottaBallsCamaro's Avatar
Ultimatesuspension
What would you do to your suspension(short of an IRS)?
We are the future, the 21st. century dislexyic, glue sniffing, cyber *****, with homicidal minds and handguns.
Old Mar 28, 2001 | 10:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on what you want to do with the car. Using Steve Spohn's parts is a great improvement over stock parts.
I'm currently working on getting a 9" rear end for my car. Although I have all the trick parts already suspension wise, I'll probably be ripping it all out and installing ladder bars.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Mar 29, 2001 | 06:55 PM
I thinking of autocrossing...
Old Mar 29, 2001 | 09:30 PM
NJ SPEEDER's Avatar
the quick, easy, and off the shelf of it is:
1: the steve spohn rear rig with all rod ends, creates a nice smooth range of motion.
2: eibach pro kit springs, lowers the car about 1.5inches and are stiffer than the stockers
3: a good triangulating strut tower brace, something that connects the towers and the firewall.
4: and bilstein heavy duty shocks, yes plain old off the shelf ones.
5: some sort of subframe connector, depending on iof you hafta sweat class rules or not you may want to look into this, the alston tubular chromoly ones work great and are scca street modified legal.
6: then look for some nice big tires, our cars can handle 17x9's with 275/40 17's. i suggest kuhmo victoracers as my tire of choice
i know that this combo works really well, i used it to great success all last season. i could even keep up with an awd mitsubishi eclipse with twice as much hp as me. the car will turn in like a monster on this set up, learn to counter steer!!!
hope this helps.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Apr 7, 2001 | 01:08 AM
Do you think having 17*11's would take care of some of the oversteer?
Old Apr 7, 2001 | 11:01 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I would do the following:
Torque arm
Subframe connectors
STB - 3 point
Rear control arms
Panhard rod
Kenny Brown lower brace
Front adjustable coil-overs
Rear weight jacks
ZR1 rubber (275/315R17)
For the curious out there, I have everything but the torque arm and KB brace and it doesn't oversteer at all, unless I nail it around a sharp turn (the car is about 390hp), even then it "floats" more than slides. The car even has 16" rubber, although they are Michelin Pilots, and 17" rubber would help even more. I would also like to mention that the car is very light on the ends: fiberglass hood and hatch, no a/c, aluminum heads, no spare and jack... Still streetable, just hope I don't get a flat-no spare fits over the big Baer brakes. I guess run-flats would fix that problem.
One thing I will say about a fully modified Camaro suspension: it will not feel as tight as a BMW or Audi (or other slow, overpriced euro sleds), but it will give them such an a$$ whooping its not even funny. Then again, nobody who buys a car like those would even have a clue about anything fast anyway.
Ch-Ching! I'll take the Camaro with the 1.05g handling instead of the Beemer and get back $30,000 change please.
Paul Huryk, billionare in training.
Monkey Guy Racing
Almost part of the moderately infamous NJ in-your-face all goomba crew
Do it right the first time.
Paul's home page
1985 IROC LG4 POS Best: 15.20s at 92.1mph
1984 Camaro 350 LG4 Best: 12.21s at 121.7mph
The smart person pays for something today so that more is received tomorrow.
The ignorant person gets something today and hopes to have enough money to pay for it tomorrow.
