Those of you running a torque convereter lock up switch.......
Car: 1991 GTA Convertible
When do you turn on the torque converter lock up swich when racing the quarter mile? I leave mine off until I get to 3rd gear and wait for the RPM's to reach around 4500 to 5000 then lock it up. Is this the best time to do it? I've had consistent 1.91 60 ft's.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
you should turn it on at the line. it doesn't lock up in first gear it only lockes up the converter from 2nd gear on up. what it does is instead of some lag in the rpms dropping it will hit harder like a manual car does. if you roll slowly with it on the car will go to 2nd and should bog like its locked in as if it were a stick.
hope this helps
Andrew
Andrew Peery
1987 IROC, 305 TPI, T5
Flowmaster, Ported Plenum, Accell plugs, Wires, Cap, and Rotor
All smog equipment gone and no cat
192hp and 265tq (at rear wheels SAE corrected)
15.20 @ 92.5 mph with a 2.4 60ft
hope this helps
Andrew
Andrew Peery
I'llrocya
Feb 2, 2016 11:43 PM
