Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
3RD GEAR TOP SPEED
Old Apr 11, 2001 | 05:16 PM
410GEARRATIO's Avatar
3RD GEAR TOP SPEED
What would be my top speed in 3rd gear with 410 gears, I have a 700r4 and a 305tbi.
with 28 in tires. I need to know what I can do to run at the track with out running out of breath, before i get to the end of the 1/4 mile..And if there anything i can do to reach the end of the track..
thanks
jon
Old Apr 11, 2001 | 05:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
With a 5000 RPM redline it's 101.6 mph.
Old Apr 11, 2001 | 06:21 PM
Thanks!! So I wont have any problems at the track???
This is the best site, I always get the info
im needing thanks guys!!
jon
mods
14x3 open element k&n air filter,
hypertech stage 2 chip, 160 switch, 160 thermo, hypertech underdrive pullies,
smop pump delete,gutted kat, straight pipe no
mufflers, b&m cooler ,shift kit and 410 gears.
Old Apr 11, 2001 | 07:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd need about 275 RWHP to the ground to break 100 mph in the 1/4 in a 3400 lb car. If you have less then you're not going to run out of gear before the end of the track.
Old Apr 19, 2001 | 10:50 AM
Nitro Don's Avatar
I had 4.10's in my 305 TPI a few years back.
With the 700R4,I was hitting almost 5500 RPM in third gear at the end of the 1/4 mile.If I can remember right,I was hitting a little over 90mph at the finish line.
I dropped down to a set of 3.73's and ran faster.
Hope this helps,
Nitro Don
Old Apr 19, 2001 | 02:11 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
With a 5000 RPM redline it's 101.6 mph.</font>
This is assuming no torque converter slippage. This is where I made my mistake in selecting my 3.73's. Assume at least 15 percent less speed than calculated.
1992 Trans Am
May 10, 2023 07:19 PM
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
