Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Wheel Stands
Old Apr 20, 2001 | 11:57 PM
bhaas's Avatar
Wheel Stands
How much horse power is needed and rearend setup etc. to do some decent wheel stands.
Thanks.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
Old Apr 21, 2001 | 12:08 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
On a typical nose heavy street car about 500 rear wheel HP (if you can get it to the ground) should lift the front wheels a little bit off the ground. Don't forget that late 60's big block muscle cars had that kind of power and still couldn't do it.
You can do it with a lot less HP with proper weight distribution, gearing, shocks and suspension. It's not really the HP that's required but the torque. Put some 5.13 gears on a car with 26" tall tires, add in some 90/10 drag struts on the front and maybe only 350 HP would lift it. Trouble is you'd probably just spin the wheels instead.
Old Apr 21, 2001 | 07:57 PM
bhaas's Avatar
Bummer. But I see them so often. Guess you gotta have lots of power and money.
Thanks.
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
86CamaroDan
Sep 29, 2015 10:08 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
ericjon262
Sep 11, 2015 06:07 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
